front end parts
Date: 03/30/2018 12:48 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
parts needed
Date: 02/20/2017 07:58 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 09/21/2018 11:35 am
Date: 01/18/2017 05:35 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 12/13/2016 10:25 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
  • Online today: 437
  • Guests: 444
  • Total: 444
Air entering cooling system??
Started by stinsonj, February 17, 2011, 04:41:04 PM
RSM
That sounds like the next logical step. Take a good look at the head for cracks. Good luck!!
stinsonj
Im in the process of replacing the head gasket to see if thats the problem.  Read somewhere if your head gasket is messed up, you can have exhaust gases entering the cooling system without any coolant loss.  Hopefully thats it
RSM
small crack in the head...head gasket....it's hard to say.
stinsonj
I bi-passed the choke, thinking that could be a place where air could enter, but still having the same problem.  Im stumped and it seems like no one has had this problem before
stinsonj
I do not have excess water coming out of the tailpipe and the only coolant im loosing, which is minimal, is through a small hole in my radiator.  The engine is actually in an old jeep, so im using the jeep radiator, which doesnt have a coolant resevoir, just a drain tube.
RSM
Something to check is the coolant resevoir and hose. If you don't have a good tight connection on the hoses or the hose has a hole in it, it will draw air into the system. This will give you the problem your having...
Cheeseliner
Stinsonj, do you have excess water coming out of the tail pipe? Do you have to keep adding fluid to it? I just wunder if you dont have a head gasket slowly seeping into a cylinder on one of them. Ive got a 75 and never had that problem. Kenny
75 Pinto Hatchback Runabout. 2.3 EFI Turbo Charged Pinto with C4 and 8 inch 4.11 locker, Front mount IC, NOS, Walbro/T-bars/ Drag Stars
stinsonj
I have a 1975 2.3L that seems to be sucking air into the cooling system somewhere.  I have burped the thing about 6 times, everytime i get quite a bit of air out, but the constant rising and lowering of my water temp persists.  Is there any way that this engine could actually be sucking in air somewhere or do i actually have that much air in the system?  I did recently transport the vehicle from about sea level to 4500 which is where its at now, if there was some existing air in the system, it would have expanded, but still doesnt make sense that everytime i burp it i get more air to come out.
