Date: 04/06/2017 12:13 am
Date: 03/13/2021 12:57 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 02/03/2018 11:28 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 05/15/2022 11:36 am
  • Online today: 489
  • Users: 1
  • Guests: 250
  • Total: 251
  • Pinto916
inertia fuel pump switch
Started by oldeguy, February 17, 2011, 08:18:09 AM
oldeguy
looks like I'll do the the belt and suspenders approach. Thks
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
Mike Modified
Draw your Walbro power directly from the battery/starter solenoid (thru a big fuze or appropriate fuzable link) via a 30 or 40 amp relay.  Wire the inertia switch into the control circuit of the relay (either the low amp power or the ground).  Belt and suspenders safety!
oldeguy
building a 2.3 EFI turbo pinto, need a inertia switch. Looking at the Ranger switch...will this support the current draw of a 255 lph Walbro pump? or other recommendations? Thanks...
