  • Online today: 529
  • Guests: 352
  • Total: 352
8 or 8.8 rears...
Started by Jinxter, February 10, 2011, 05:09:06 AM
vonkysmeed
mustang 2 with the v8 is a direct swap onto the springs and maintain the 4 lug 108 configuration.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
Don't forget, some mustang IIs had 8" rears. That's what the 8", that my 78 will be getting soon, came from.
From the research I have done, the Mustang II 8" should pair up just fine with my 4spd transmission and stock drive-shaft without any issues!
When you find an axle, don't forget to get brake shoes and hardware, as well as the necessary gaskets to recondition it.
stormy69
has anyone installed a tbird or mk8 irs in a pinto?
Jinxter
Thanks, G!  Now to go see what's available...
Beat it to fit, paint it to match...
Grumpy
Jinxter
I measured mine at 56 inches(79-80?), a stock explorer is 59.75, as are some mustangs. The IRS here is 60 by my measurement.
Given late model wheels or aftermarket ones these will fit and you can get them cheap and grind off what you don't need and weld on what you do. The IRS is a 3.55 positrac unit and it needs late model wheel offsets anyway(at least 17 inch wheels). Believe it or not, Volvos after 1997 have 8.8 rears, disc brakes but I'm having trouble finding a width.
Here is a handy chart.
Grumpy 8)
79 Pinto Hatch, Yellow w/White Pony stripes, Pony wheels, 6650 miles
oldeguy
if you think that will be hard to find...try this one. Maverik 8 inch, it's 57 inches wide, i think the spring pearches are in the proper location and it has the bigger bearings? lots out west!
BTW, look in the for sale on this forum...Pinto1? just posted an 8 inch.
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
Jinxter
Wish me luck on finding one of those!!
8in from a V6 pinto/bobcat or mavrick
Jinxter
I know it's out there somewhere...  Does anyone have any files, links to a database, list, something that shows what rears can 'easily' swap to the Pinto?  I want to make a run to the salvage yard soon and grab one.  Thanx!
