Date: 09/01/2017 07:52 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 09/10/2018 10:41 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
74 Wagon Interior
Date: 01/22/2017 06:38 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
  • Online today: 515
  • Guests: 268
  • Total: 268
74 pinto wagon - 85 turbo coupe problems
Started by carbomb, January 31, 2011, 04:41:58 PM
i have an extremely built motor in my pinto... i use a standard felpro 8993 headgasket.... ive seen 30+ psi,(accidentally) and i run the crap out of this car... my stockblock first engine was near 400hp... all mods were the head intake exhaust and fuel system....dont be scared to use the stock headgasket.... they work great..
i know when ya just hook the lines up with a IHI turbo it runs around 10 psi of boost id say at most it would be around 12 and if ya want more just get a manual boost controller to replace the factory one with leave the stock one in place though so it doesnt show a code.
carbomb
how safe is this to do? how many pounds of boost? i heard the stock head gaskets don't like over 18 but i know a guy who has ran 22 for 70000 miles by doing something like this
the 2 hoses that go to the boost control selenoid..... unplug those hoses from the selenoid and connect them together.... thats it..... leave the electrical connection to the boost control plugged in.....lower left of diagram
carbomb
hook the ones on the engine together ? or the ones on the bps? and plug the other ones. I have been told this but i'm not sure exactly how to do it.
just plug the wiring to it and take the 2 vaccum hoses and connect them together.... the ecu only sees the device and wont set a code if you do this... it will also bring boost up a couple pounds more doing this...
carbomb
never mind figured it out was a wiring issue but does anyone have a boost pressure sensor i could buy mine fell apart i put it back together and now it doesn't work right
carbomb
i recently put a 85 tc engine in my 74 pinto. we didn't do any modifications to it just cleaned it up put a new oil pump on it and put it in. It is not running correctly. it idles fine but when i give it the gas it just chokes and makes bad noises. we thought our ignition was weak and fixed that and it is still doing it. it doesn't build any boost just levels out at 0 vacume 0 boost. what could of we hooked up incorrectly or what could be causing our problems. Low fuel pressure possibly? a sensor messed up?
http://beammark.net/pinto.html
