Date: 09/15/2019 12:38 pm
Squire trim
Date: 03/28/2018 10:11 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Date: 06/07/2021 08:14 pm
Date: 10/02/2017 02:16 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 12/30/2022 01:30 pm
Date: 04/30/2023 04:31 pm
  • Online today: 587
  • Guests: 286
  • Total: 286
2.3L Turbo Questions
Started by pintoguy76, January 18, 2011, 03:01:43 PM
Quote from: Bigtimmay on January 18, 2011, 04:01:03 PM
For you Headgasket/o-ring thing most guys are just running the  Fel Pro 1035 head gasket it has a wire ring built into it around the cylinders. But if your going to run this headgasket you need to make sure the block is flat and the head is flat if they aren't you can have issues with it sealing.
I'll have the head and block milled as little as possible to make it flat if it is not already. Still afraid it might pop and then need to do all the work again. What about a cometic gasket or an MLS? Or a copper gasket w/o the o-rings?.  There is a site i ran across last night that sells 2.3 copper gaskets in both self sealing and non self sealing types.
Oh and since your aiming for 300-400HP if i was you instead of the 190LPH fp id just get a 255LPH JDs performance has genuine walbro 255lph pumps for 119 not a whole lot more then what the 190 costs.Plus its always better to have more fuel then need then not enough later on.Jds also sell the kirban adjustable FPR.
Yes the 255lph is what I meant. Its been a long time since I did any reading up on this 2.3t stuff so 190lph is what came to mind. I was however planning to use the larger pump. Might be a good thing you mentioned that or i might have forgotten the 255 was available.
"LB2 computer with ACT sensor (LA3 is better I know but the car I got the engine from was an automatic which had the LB2 computer)LB2 computer with ACT sensor (LA3 is better I know but the car I got the engine from was an automatic which had the LB2 computer)"
Actually the auto computer has the same tune as a la3 the only difference is the boost they put out but since your running MBC you wont have a problem with this.The auto ecu was set to run lower boost due to the trans couldn't hold anymore.
I thought the auto computer had different timing maps as well. I dont know if it would make that much difference or not tho.
I thought the early TC and SVO had a T3 stock and the 87 88 like mine had an IHI. The t3 fit with no problems (other than oxygen sensor hitting the heater motor) and the IHI had clearance issues with the wastegate actuator.
Clarify this for me please?
I was planning on using the IHI that I have so some surgery was expected anyways... Ive been considering a header that moves the turbo forward some which may eliminate some or all of the clearance issues anyways. Ive seen some adapters on ebay that adapt one turbo to another turbo flange.. like a t3 to a t4 or vs versa. That adds 2 or 3 inches of height to the turbo which would help more on clearance below but might get into the hood then.
Mike Modified
T3 requires surgery
but the results are worth it  :lol:
http://www.jdsperformance.com/index.asp?initemuid=432&fcmd=item&inmake=0
I'm about to start working on my 87 Thunderbird turbo coupe engine soon (after a couple other small projects are done)
It is a low mile (63k) engine std bore. Crosshatch clearly visible in the bores. Bores look awesome.
Crank and main bearings, not so much. Some evidence of dirt and scratching and there is some copper visible in some of the bearings. The crank will need polished at least and probably turned polished and all bearings replaced.
Before I go much further I would like to say that I dont really PLAN on getting overly carried away with this thing, maybe 300 or 400hp at most. There are guys making 700+ hp with these and they are needing (barely but still needing them) straps on the main caps, aftermarket rods, etc.
I plan on using ARP main and head studs as well as ARP rod bolts but I think stock pistons rods and crank. Keeping my original bores and pistons but MAY consider total seal rings.
My main concern is the fact that people do blow head gaskets alot on these engines. There are of course solutions to this. Copper head gaskets and head gaskets WITH or WITHOUT O-rings.
I think going WITH o-rings would be best, that will seal up the cylinders pretty well. Then i assume sealer is needed to be applied between the block/gasket and head/gasket to seal up the water and oil passages.
How much would it cost, approximately, to have the block machined for o-rings? Are the o-rings reliable for street use or are they something that I will have to tear into every year or two and replace and would this need to be done for the copper head gaskets, if not for the o-rings? I am looking for a reliable very street friendly while being a fun high performing machine.
Engine will be going into a 74 Ford Pinto wagon - about 2400#-ish
Plan on using stock intake exhaust and turbo for now but thinking about rotating the intake for a front mount intercooler and probably a header and T04E turbo at some point in the future. The engine will be mainly stock for now but I want to do the internal work preparing it for more power now before I put it in the car. Id put in a windage tray to wipe the oil off the crank which is good for 20hp the way I understand it (on a v8 anyways) but I dont know if they make that for a 2.3L ford and the product description for the ARP main studs says its not compatible with a windage tray so thats probably out of the question. Probably not needed anyways, these engines are very capable of making all the power you want without all the little things.
I plan on either a ranger roller cam - or an aftermarket cam and MAYBE some port work and large valves on the head. No need for a $2000 aftermarket head I dont think and its not in my budget.
So to recap, to start off with this is what I am planning on:
Stock block and head, maybe o-ringed w/ copper head gasket
Ranger roller cam and followers
Stock pistons and rods (with ARP bolts) and maybe total seal rings
Stock crank, turned as little as possible
Stock intake and E6 manifold, maybe ported, gut the intake and open up the throttle body a little.
Probably the TC intercooler for now
Whatever injectors are on the engine now. (They're the big stock ones 35lb/hr if I remember right)
Adjustable fuel pressure regulator and 190 LPH fuel pump.
Stock turbo - I think. (Its an IHI which IIRC has an external wastegate which I think interferes with the inner fender on a pinto. The T3? turbo used on the 83-86 TC works fine with a pinto from what I remember)
Adjustable boost controller
Big VAM
Air intake routed outside the engine compartment for cooler air
Balanced rotating assembly?
[/size]
Probably more that I am forgetting. This has been in the plans for years just had too many other projects going on so I am a little rusty on some stuff and forgetting others I am sure.
Any comments or answers to my questions would be GREATLY appreciated.
Thanks guys
