Date: 11/14/2019 04:02 am
Date: 06/05/2018 09:13 pm
Date: 02/03/2018 11:28 am
Date: 01/12/2019 10:19 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 05/21/2019 11:50 am
New cam
Date: 01/23/2017 05:11 pm
Date: 07/17/2018 09:22 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
  • Online today: 533
  • Users: 1
  • Guests: 458
  • Total: 459
master cylinder brake rod attachment
Started by oldeguy, January 10, 2011, 08:31:17 AM
oldeguy
Your not bad...I just feel real stupid after...taking a good look today, a spring pin...then the plastic washer falls off, and it comes apart. Doh!
thanks,
bill
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
Whoops, my bad.  Just release and slide the cotter pin clip off.  If you loosen the master cylinder some you can wiggle it off the pin easier along with the brake light switch.
oldeguy
Quote from: TIGGER on January 10, 2011, 08:52:11 AM
You usually end up destroying the clip when you remove it from the bore.  If you are replacing the master cylinder, they usually come with a new one that just needs to be installed.  In the past I have put the MC in a vice and pulled the rod out with some vice grips.
tigger...I'm refering to the rod onto the brake pedal...
oldeguy
How do you get the rod off the brake pedal? looks like a spring clip of sorts...and good pictures of this?
