72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 04/04/2020 09:38 am
1973 Pangra
Date: 01/06/2015 02:19 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 01/19/2020 09:06 am
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Date: 02/08/2018 02:26 pm
  • Online today: 600
  • Guests: 346
  • Total: 346
4 wheel disc brake plan/questions/comments
Started by oldeguy, January 06, 2011, 09:49:59 AM
dave1957
on my 79 turbo project im using the 8.8 from a 88 tbird you will need a different proportioning valve my rearend is only approx5/8 inch wider the pinto rear end
i have also looked into a kit by currie enterprises that lets you use the 8.8 disc brakes on an 8 inch rearend
1979 bobcat
1974 red stinkbug
oldeguy
he is the plan for my 72 hatchback...11 inch front rotors, not sure if it will be Granda or something else with GM alum. Meter calipers from wilwood for the front...rear will be a narrowed 8.8 T/C disc brake unit utilizing the standard disc set up. the questions are...#1 is this a good plan? #2. will the standard 15/16 bore pinto master cylinder be OK to use? #3 will the brake balance front to rear be ok? any feedback will be welcome!
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
