Date: 12/15/2018 02:21 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 03/06/2017 01:24 am
pro stock front end
Date: 06/28/2019 07:43 pm
Date: 07/04/2022 07:55 pm
Date: 04/28/2018 04:12 pm
Date: 01/24/2017 12:36 pm
  • Online today: 452
  • Guests: 251
  • Total: 251
? 78 302 oil pan
Started by lateniteauto, January 04, 2011, 05:22:45 AM
vonkysmeed
any one have pictures of backdating / lowering their rack?  Working on a subframe connector now, but will put that on the next list of to doos.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
Pinstang74
I had a 351 C in my 74 hatch back and only had to use a front sump pan to make everything come together. Did have to move one of the frame engine mounts back an inch or so. The headers is the only trick. Still have the new set of Hooker Pinto Ford small block conversion headers if you need some. The two rear Number 3&4,7&8 run straight out through wheel wells and collect below.
lateniteauto
71hot... thank you very much.  This was very helpful.
71hotrodpinto
Well im not sure about the 73 and up. The 71 has horizontal "pads" that the rack bolts to. I cut mine off and moved them down then re-welded them. AND to get the rag joint to clear again i had to cut and box up some clearance in the top part of the cross-member. Not a job for the timid fabricator. I Imagine i could've had some more clearance with just a after market u-joint, but i just didn't have the extra cash and i wanted to retain some shock absorption in the steering wheel.
The most important thing is to make sure its parallel with the cross member in both looking down on the cross member and in looking from the front. after your finished. THEN you need to install a "bump steer kit" basically making the tie rods parallel with the lower control arms again. Otherwise it will be all over the road
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
79prostreet
Quick question for 71 hotrodpinto, whet does a person do to drop the rack down 1.5? I'm dropping a 351w in my 79 cw,Im hopping to lower it down and move it back a few. Needless to say I will need some type of oil pan, will more than likely have custom make one. Thanks 79prostreet.
79prostreet
71hotrodpinto
Yes this one. The first picture. The flat and square area im talking about is right here in the red circle. They are more expensive by far. But hey in some small way your supporting an american job and it fits.
There is one on ebay right now.
http://cgi.ebay.com/ebaymotors/Milodon-289-302-Ford-oil-pan-and-pickup-_W0QQcmdZViewItemQQhashZitem1e60d0192aQQitemZ130473269546QQptZRaceQ5fCarQ5fParts#ht_500wt_1183
I wish it was mine to sell cause i need the money! LOL!  But it isnt. Just doing a little foot work for yah. Also this one comes with the pickup. A good deal IMO.
The the other one that im showing you is the stock pan modified without the flat area that just happens to clear the rack on the Milodon pan.
They may fit and work the same on the engine but it will cause the engine to sit higher in the chassis to clear.
Edelbrock Airgap
Mil
Quote from: lateniteauto on January 09, 2011, 04:36:12 AM
71hot...   do you have a part# for the Milodon.  And could you explain what you mean by "the flat and square area"?  I'm not in a rush, just don't want have to return anything.  I am still in the middle of building my 302.
This one ?
http://www.milodon.com/oil-pans/street-oil-pans-ford73.asp
lateniteauto
71hotrodpinto
Get the milodon pan. Its expensive and you may see it hanging down depending on your front end. Mine is just level with the crossmember after lowering the rack 1.5".
Dont forget the pickup as well.
Also dont get the copies either. They are just stock pans with a sump. They dont have the baffling or the flat and square area that clears the rack.
GL
Edelbrock Airgap
Mil
Quote from: RSM on January 05, 2011, 09:10:58 PM
whats your problem dude?
Are you two still at it?? Are you both going to Carlisle? I can bring my boxing gloves...:D..
Quote from: popbumper on January 05, 2011, 01:12:18 PM
Yeah, email RSM, he'll fix you right up. If you're wrong about something, or he doesn't like what you've said, he'll let you know. He'll even tell you about the access hole cover in the driver's fender if you are interested.
I had a pan built from a blank core...6 years ago it cost me 165.00. http://www.fordpinto.com/your-project/302-into-77-wagon-oil-pan-modification/msg9637/#msg9637 I documented my entire conversion here on fordpinto but at the time I did not know to make one continuous thread and in the beginning of the project had numerous threads. I would be happy to speak to you on the phone to explain my experience.
RSM
Quote from: RSM on January 05, 2011, 06:10:29 AM
There happens to be a pan on Ebay right now too.
RSM
RSM
You can actually find the Mustang II pan once in a while on here or on Ebay. I sold one last year for about $125 and it was in like new condition. There are several discussions on here about V8 swaps. I have a 1979 w/289 and a C4. You can email direct if you need some info on the swap. rsm2006@msn.com
lateniteauto
Could anyone tell me if this oil pan (http://www.summitracing.com/parts/MOR-20502/SuggestedParts/?prefilter=1 ) will fit a 302 swapped in a 2.3L 78 sedan?  I really think this would be a good one, but would like to get some feedback from someone in the know, before I spend this much money.  Any advice, knowledge, or other part numbers would be very helpful. Thank you.
