1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 05/21/2019 11:50 am
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 03/05/2017 03:27 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 11/08/2020 02:10 pm
Date: 08/26/2018 06:23 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 02/11/2020 12:09 am
  • Online today: 587
  • Guests: 294
  • Total: 294
2.3 turbo swap
Started by little red, December 21, 2010, 06:11:30 PM
little red
There is a few more questions about  some parts that I have like y does the idle speed actuator have 6 wires coming out of it  but the diagram only shows one in and one out also there is a sensor that is located under the intake that looks like it goes to either the oil cooler return or is a water temp sensor im really not sure  im looking some solid info that can help me
whats up peps I own 73 runabout 2.3t swap, spd, pimp ecu, subframe connectors. Ive had this car for 10yrs and have done the work my self the car has been in my family for 30yrs. Alway looking for parts and I have a few my self too, please feel free to message me
Cheeseliner
Good Deal Big. Post some pics when you got em...
75 Pinto Hatchback Runabout. 2.3 EFI Turbo Charged Pinto with C4 and 8 inch 4.11 locker, Front mount IC, NOS, Walbro/T-bars/ Drag Stars
oh i have my diagrams already my swap used a merkur harness repinned for my 88TC motor and la3.
Cheeseliner
BigTimmay. I think i have the 85 TC wiring diagram if you havent found one. my email is ken-eaton@sbcglobal.net
Shoot me an email if you still need it. Kenny
You may want to add a resister that matches the impedence of the EGR solenoid so that you don't have a dead short and mess something up.
well from the looks of the wiring diagram the egr solenoid has a constant power too it and the ecu grounds through pin 35 so in theory i would think the wires could be wired together to get rid of the code for the egr solenoid.
little red
thank you for the insite i guess what i should have asked is how do i get the ecu to not throw a code for the egr becuase i removed it when i made  my intake
Here is the Saab (not Volvo*) intercooler and the plumbing that I mocked up for it.
http://www.fordpinto.com/your-project/'palomino'-the-turbo-swap-in-progress/msg49533/#msg49533
http://www.fordpinto.com/your-project/'palomino'-the-turbo-swap-in-progress/msg58454/#msg58454
I need to get back to finishing up upgrading my Pinto XR4Ti into a Pinto SVO, but I'm having too much fun letting it slide and just driving the car around around. Can anybody recommend any good tube benders in the Omaha and Bluffs area?
*Although I have a spare Volvo IC that I would sell. (I hope that I just didn't kill the market....  :P  )
what im looking for is a 85 turbo coupe exact wireing diagram-
http://www.rothfam.com/svo/reference/85SVO-Thunderbird-Merkur.pdf
i need to know how to baypass the egr-
you wont gain really anything by removing it but if you must its pretty straight forward just block it off
wire in a electric fan to come automatic-
use somthing like this http://www.jegs.com/i/Mr-Gasket/720/1992/10002/-1?parentProductI d=763733
as well as coolent  temp sensor back to the computer-
see wiring diagram
also if any body has info on how to route my fuel pump from the stock gas tank.  so that i can get the proper fuel
flow to the pump-
make a bracket to mount the pump too that will hold it close to the same height or lower then where the line comes off the tank if possible.
Or you can weld on a sump kit and this will help keep the motor from ever getting fuel starvation. http://www.summitracing.com/parts/CEE-4041
plus then the pump can be mounted on the side of the tank and lower then it would be in the original position.
also what type of adjustable fuel regulator to use (return style or pressure side)- Well first off are you using the orginal fuel rail or custom/aftermarket? that being said if your using a stock rail http://www.jdsperformance.com/index.asp?initemuid=147&fcmd=item&inmake=0 will work just fine.
hope some of that helps ya out im in the process of this same swap cept mines in a 78 bobcat all im lacking finishing up is installing a fuel cell and fuel pump.
little red
thank you but now that you say saab i dont know y i typed volvo i done  have a
sab intercooler (86-92i believe). As far as the upper intake i had to fab one thats 120 degree it faces the driver side head light . my hood has louvers so i built it for clearence i didnt want to butcher my hood
You shouldn't overlook certain Saab intercoolers. They're also largish and they have both outlets on the same side. This way you could run both pipes down the passenger side so that you don't need a rotated upper intake manifold or other whacky plumbing.
little red
ive done everything that it took to get the engine in  my 73 sadan  im lookin for the final info to get it running perfact
some of the thing i got goin for the car is
255 walbro inline fuel pump
86-92 saab intercooler
i use an 85 turbo coupe for the harness
also the drive tran
its 5 spd
i need to know how to baypass the egr , also  wire in a electric
fan to come automatic as well as coolent  temp sensor back to the computer.
flow to the pump.
if any body has some info  i would really greatful  (please and thank you)
