Date: 08/22/2018 09:23 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 11/23/2017 05:44 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 05/22/2018 01:54 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 452
  • Guests: 199
  • Total: 199
2.0 to ? What's the easiest swap for a 72
Started by marksm, December 07, 2010, 05:26:09 PM
Quote from: 71hotrodpinto on December 18, 2010, 02:02:02 PM
Hanto, truly an awesome and fairly easy swap!
However cost is truly and issue here. I mean $3500 just for the head? wow Your in V8 swap territory. then theres the fab work again.
Truly id get a nice 2.3 carbed setup and just stick with that.
Dont get me wrong i love the idea of a lil 4 banger with some more individuality but my guess is this gent wants to also do this fairly cheap as well.
Thanks 71hotrobpinto...was building this 1600 Cheap?...NO...is it different?...Definitely...Passing a V8 pinto in the first corner on the OUTSIDE...Priceless... :hypno:
All kidding aside, rebuilding the 2.0L with some go fast goodies (intake, carb(s), cam, headers), changing the rear gears, and adding a five speed trans may be the best bang for the buck, IMHO.
71hotrodpinto
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
Here is a Twin Cam head from Lotus (still being produced $$$ Dave Bean) that fits a 2.0L. This one is on my 1.6L. There is also a 2.0 Cosworth Twin Cam and the Ztec (SVT) Twin Cam. The original Hanto Pinto (1974) was a 907 Lotus Twin Cam. I used a T-9 5 speed which is just a Pinto 4 speed with an extra 5th gear (came from a 2.3L Merkur). I adapted it to fit a 2.0L bell that was the original engine in my 71. The T-5 requires the trans tunnel to be cut forward 1.5 inches. The T-9 does not. However, the T-5 is stronger and a dime a dozen.
72pair
I'd like to know more about this 2-cam head also. The only way I know of putting a T-5 behind a 2.0 EAO is cut/weld a 2.3 bell or not use the top bolt holes. JT
marksm
Quote from: Turbo Toy on December 17, 2010, 08:21:29 AM
Why not just build a good, hard running 2.0 with a turbo and use the T5 bell,flywheel and trans. It would be a kick butt combo and different. If I had to do another Pinto, I would definately use the 2.0. It even has a readily available twin cam head and is a bullet proof botom end.
I know nothing of the 2.0 really, how would the T5 fit onto it? Tell me more about the twin cam head.
1972 Pinto Wagon with Cruisin panels on it
1973 Ranchero Squire
2006 MX5 Sport
2007 Buell XB9S
The downside of a turbo on a 2.0 is the carburator vs. EFI on a 2.3, but it is very do-able. Turbo Toy, where are you finding the DOHC heads for the 2.0 and what kind of money?
Just for the record, stock vs. stock or mod for mod, the 2.0 will spank the 2.3 any day, but high-performance parts for the 40 year old 2.0 are getting harder to find. Esslinger and Racer Walsh no longer carry stuff for them.
Turbo Toy
72pair
I did this about 15 years ago. Put mounts out of a 74 in my 72 after removing the @#$! spot welds. I was able to use one of the original bolt holes at the top of the mount. Drilled the frame for the other top hole, then welded the bottom when I had the exhaust done. I'm running an electric fan because I ended up with about 1 1/2" between the pulley and radiator. I love 2.0s, but at that time(pre ebay for me) parts just weren't easily found. A 2.3 and T-5 is has way more bottom end as a plus. JT
You could try a fresher 2.0.
But that might be too straightforward and easy to be all that much fun....  ::)
Ending result's.  Fred    ;D ;D ;D    :P
Mark, I have a 94 Ranger engine with 5 speed in my 73. I used Ranger eng. mount's and frame mount's I fabricated.  Fred   :)
71hotrodpinto
Quote from: Farmboy on December 07, 2010, 09:56:54 PM
  Gonna have to remove the motor mounts if you are going to change to a 2.3. its not a EZ job, there spot welded in and they do a really good job doing it
Having said that, its still the "easiest"  swap of all the thoughts out there. the 2.3 is also longer by a bit so youll have to get creative.
Hopfully someone that has done it will chime in soon for ya.
GL
Edelbrock Airgap
Mil
Farmboy
74 Pinto Wagon
71 Runabout (parts car)
marksm
Engine is dying. Would like to use something more modern with a 5 speed. Will a 2.3 use the existing motor mounts. What all would need to be done.
2006 MX5 Sport
2007 Buell XB9S
