Date: 09/26/2019 05:31 pm
Date: 10/03/2018 10:46 pm
Date: 08/20/2017 01:34 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 01/30/2017 01:48 pm
Date: 11/11/2019 04:49 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Date: 10/28/2018 08:45 am
Date: 04/20/2017 08:56 pm
  • Online today: 1,137
  • Guests: 531
  • Total: 531
2.3 Turbo Transplant project
Started by Cheeseliner, December 06, 2010, 06:32:08 PM
Pinstang74
Nice looking Pinto. I did an 89 2.3L EFI swap some years ago and always thought that the Turbo coupe would be a nice swap. The height of the 89 2.3L EFI fit perfectly with sock mounts and T-5 trans.I worked the engine bay to fit the 351C some years before so the newer 2.3 went in fine. Everything should fit ok with stock mounts. The only thing you may run into it the trans mount for what ever you are going to install. The Pinto is a tough little guy that can take a lot of changes. The Power Rack and Pinion from an 89 Stang will fit and work great also if you drop the mount holes and inch. Just be carful if you get a high rate rack and pinion as you can easily over steer and spin out with the Pinto's short wheel base. ( know this from experience ).
Cheeseliner
OK Little Red. I sure will. I have the harness from the 85 TC too. Sorry i haven't been on here for a while. I'm getting tire of the snow and cold here! Anyway, ill let you know how it goes. I have a friend that's done it before. He laid all the wires out on the garage floor and had his book. He eliminated all the wires that he would not need and it worked out great. He put the motor in an ole model T pick up truck. Catch you later. Kenny
75 Pinto Hatchback Runabout. 2.3 EFI Turbo Charged Pinto with C4 and 8 inch 4.11 locker, Front mount IC, NOS, Walbro/T-bars/ Drag Stars
little red
hey cheeseliner if you can when you get to the wiring let me know how you went about it so
i can compare notes. Im useing an 85 T/C wiring my self   that i pulled out of my doner car
I dont know if you plan on going with the stock harness from a doner.
but there is  missing peices that dont make sense i could
use the help.  thank
whats up peps I own 73 runabout 2.3t swap, spd, pimp ecu, subframe connectors. Ive had this car for 10yrs and have done the work my self the car has been in my family for 30yrs. Alway looking for parts and I have a few my self too, please feel free to message me
Cheeseliner
Nice. I am toying around with the idea of making a mold from my good hood and making some fiberglass hoods from the plug. :)
rkk
About 3/16 is all you need .  The mounting flanges look real thin after your done, but I haven't had any problems in 3 years and I run the car pretty hard and have even taken it to the track to see how it ran.  No issues runs strong.
1976 TURBO PINTO
Cheeseliner
Damn. OK. The upper is easy enough to take back off. Its been too cold to go out and measure the 88 valve cover so ill wait a little longer. Its going in there one way or another ! Kenny
rkk
I milled the bottom surface of the top plenum.  Thats about as much as you can take off with it not hitting the valve cover.
1976 TURBO PINTO
Did you mill the bottom surface? Did you use a shell mill or other likely bit?
rkk
Just a note on your hood clearance problem.  I didn't want to lower my motor mounts because then my clutch cable would not clear.  What I did was use a 88 turbo valve cover and intake and mill the intake down about 3/16. It clears just barley but it clears.
1976 TURBO PINTO
Cheeseliner
Thanks Tim. Thats actually says 2.3 to C4, im not sure what the heck i was looking at! This helps alot. Thanks. Merry Christmas.
Cheeseliner
Dang, i was just on Quiktime the other day. I could not find the 2.3 to C 4 bellhousing. Unless it is listed as a diffenent number and not just a 2.3 to a C 4. Unless it is listed as something else. I ll do it again. I was in a little bit of a rush last time. Thanks Big.
Quote from: Cheeseliner on December 24, 2010, 09:19:34 AM
either that or making a steel belhousing for a 2.3 to C4. A little "fabrication" never hurt anyone!. :)
you could buy a quicktime sfi approved 2.3/c4 bellhousing.
Cheeseliner
Thanks LIttle Red and Cheapracer. Cheapracer, are you talking about the 88 upper intake or the 83? I havent been out there to look at the 88, but i do think its shorter than the 83 upper intake. Ill do some measuring with the stock motor and hood clearance then some measuring on the 2.3T one. Looks like i may have to end up making a clutch pedal for the dang thing. No one seems to have a pedal set up for a 75 HB. either that or making a steel belhousing for a 2.3 to C4. A little "fabrication" never hurt anyone!. :)
CHEAPRACER
Mine is a 74 and  the same combo does not clear the hood using stock mounts.
little red
i just had to drill the hole bigger to get the fuel to return to the top of the tank.where the stock vent
is on the tank
little red
me i use the stock hard lines in my 73
Cheeseliner
OH, is there any modification (out side of the fuel pump) that i need to do to the tank or the lines to get this thing to feed the motor? It looks like the fuel lines along the frame and going into the tank are kinda small. Kenny
Cheeseliner
OK. Ill look at the valve cover too. I am still trying to work out the clutch/brake pedals to the T5 tranny. The car was originally an automatic. Hopefully i can get something worked out.
Kenny
The later valve covers also have a valley in the center to clear the lower intake and throttle body.
Cheeseliner
Thanks! Ive got a spare 88 TC motor. (frozen). I will yank the upper intake off of it and use it. (i think it looks better anyway!)
Good idea on the elbow for the O2 sensor too! Thanks soooo much.
Kenny
I drilled and tapped a hole on the side of the exhaust elbow for the O2 sensor. IIRC, it takes a 18mm spark-plug tap.
dave1957
if you have a non ac car the o2 sensor will hit the fan  i read somewhere tha you can use another (mg?)heater motor to fix this problem
1979 bobcat
1974 red stinkbug
if you use an upper intake from a 87-88 turbocoupe it will clear fine....
Cheeseliner
Hi Everyone. I am going to take my 2.3 out of my 75 and replace it with a 85 2.3T from a T Coupe. I know i have to swap oil pans and oil pick up tubes. It looks like the 2.3T is "taller" so im not sure if its going to fit under the stock hood. I thought i read somewhere where you cut the motor mount holes a little bigger so it will set down lower in the engine bay.....Does anyone have a suggestion on this? Also any other advice on this swap would be greatly appreciated. Fred Morgan is working with me on the transmission issues and has been a big help.
Thanks! Kenny (Topeka Kansas).
