Date: 01/28/2021 03:49 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
Electrical
Date: 03/29/2017 11:37 am
Pinto Wagon
Date: 05/25/2018 01:50 pm
  • Online today: 583
  • Guests: 520
  • Total: 520
Twist, traction, & time slip guesses...
Started by guitarguy, December 03, 2010, 08:34:08 PM
71hotrodpinto
one more pic
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
71hotrodpinto
Yeah about high 13s is about all you can expect from that mild 302. you probablly have around 230hp with the manifolds choking up things.
Now if you were pushing near 400 hp with a stiff chassis, traction aids, gears etc all optimized to drag that pinto (read $$$$) then you could be doing 11s easy.
About the caltracs. Awesome traction aid. However the Pinto has no support at all considering the kind of forces that caltracs put on the chassis. Id be doing a lot of reinforcing before trying those with any kind of HP. Just food for thought.
I managed to find an OLD set of traction bars that have you remove the bottom leaf spring plate that were made for and supposedly fit perfectly on the pinto.
Subframe connectors are non existent. They were never made for the Pinto stock chassis. it has no rear "subframe". So nothing easy to connect to.
The only real solution besides installing a "back half" is to connect to the rear leafs. This is the way i did it.
I used 3 x 1.5 x .125 rectangular tubing and 1/8" flat plate. I don't know any of the dimensions off hand except the stock material i used. TIP when you find a metal yard ask for the rem section and the steel is ALOT cheaper than the "New" section.
Cut a 2.25 slot in the floorboard from front to back and bend down a "tab" to weld to eventually making the hole 3 in wide.
Push the tubing up in there, postion, tack , build it up to the leaf spring perch and then fully weld in.
Dont forget to seal and then paint.
The picures should tell the rest of the story.
Please excuse the crudity of these pictures , i was pressed for time (LOL)  The "floorboards" are roughed in. Not to scale. But they give you an idea of what to expect them to look like. The area at the rear and foot wells is fairly accurate for depth. I filled the "pockets" in with heat and noise barrier padding. You can barely tell with the carpet over it now.
Good luck and any questions let me know.
Robert
Edelbrock Airgap
Mil
Subframe connectors are a must and more then likely will be custom made by you or a shop theres a few threads on here about them already.
But as for traction bars if you can get yourself a set of cal-tracs or make your own. They work wonders on stock spring cars.
http://www.hotrodsandhemis.com/Traction.html thats a how to on making your own cal-tracs.
guitarguy
1st thought: "Dayaaammmm if I could get this car to hook it'd be fast. Think I'll get some traction bars!"
2nd thought: "If this thing ever hooks it's going to break the windshield. Better get some subframe connectors too."
Base model no power anything '72 trunk model, '72 9:1 302 with Holley 600 & RV cam, Maverick 8", probably 3:1 gears or so. Tuned up & dialed in, what kind of performance can I expect?
Experienced traction bar recommendations?
Subframe connectors the way to go? (I searched, couldn't find any ready-made weld-ins)...
Thanks in advance for piping in with your thoughts & links, etc. I'm new to the blue oval world and to this wee beastie of a car. You know when you look at buying a V8 Pinto as a simple, low trouble, easy to finish project you've been working on '70s Mopars too long. :)
