Radiator
Date: 05/27/2018 06:07 am
cam pulley
Date: 05/30/2018 04:56 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 02/14/2019 06:27 pm
Date: 08/09/2018 07:49 am
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
  • Online today: 656
  • Guests: 537
  • Total: 537
windshield trim '73
Started by Stuwil, November 01, 2010, 09:48:36 AM
I have a trim removal tool to pull the clips to make it easier.  Take the sides off first.  There are two screws, one on each side at the low end of the pilar post near the fender, that hold the ends of the lower moldings.  Remove them, then use the trim tool to pop the clips.  If you do not remove the screws you may end up bending the moldings. Then you can remove the top trim.  It takes a little getting use to the tool to pull the moldings quickly.  Just take your time.
There are small clips that need to be pulled towards the windshield to release. You can use a hook tool, or there are specialty tools for this task.
I use one like the one to the far left of this photo:
http://buildmyclassic.com/t/trimremo240.html
Be careful not to pull up on the trim to much, it doesn't take much to bend or warp the bright work on these cars.
Stuwil
Can somebody tell me the trick for removing the trim around the windshield?. I don't want to ruin it and that's just where I'm headed. Experience tells me that inexperience is expensive
Thanks
Stu
