Wanted early pinto
Date: 10/03/2019 02:42 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Date: 01/20/2018 07:51 pm
Date: 03/23/2018 09:23 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 08/30/2021 03:20 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 09/09/2018 03:22 pm
  • Online today: 488
  • Guests: 470
  • Total: 470
Help!! wiring problem
Started by Pinto Pro, October 30, 2010, 10:46:10 PM
Alrobot
I will scan them at work first thing Monday and send it to the email you sent.
Al...
Pinto Pro
Yes Alrobot, that would be great (PM sent).
I changed out the solenoid and it still wont start.
I checked that there was power while it was cranking, and there is, so I dont know what to check next.
Alrobot
I have the diagrams out of one of those old Blue MOTOR Manuals for all years of Pinto. If you think it would help I could scan them to PDF and send them Email.
Let me know.
Al...
blink77
If the opposite small terminal from the small
terminal that you use to jump start at the
solenoid is not hot when engine is cranking
then the solenoid is bad, which was what was
wrong with Dave,s car. If it is hot when cranking
I'd trace the wire from there to the coil, which is
where it goes to give a full 12volts for starting.
After some thought I believe it will be the solenoid
like Dave said, or the wire from the solenoid to the
coil, and probably not the ignition switch.
Pinto Pro
The car is a 72 model.
So if I check the small wire, and it does not have juice, then does that mean mean the ignition switch is bad??
Good point bill!
What year of Pinto are you working on? My 73 has a long narrow switch which split open recently and I switched it out. My 78 has a rectangular box type switch (bulkier and of stronger construction), which I have also changed out because it froze in the off position a couple winters ago.
blink77
My guess would be ignition switch. You apperently
have power to the coil in the on position, but not
in the start position. Something else to check would
be the second small wire on your solenoid should be
hot when cranking either with the switch or when you
jump it. It sould be hot either way.
My 73 wagon would crank and crank but not run at all, I swapped out my solenoid and it started up just fine once I got the varnish out and fresh gas in.
lugnut
I'm not clear on your question- at the beginning you said that it will crank in neutral and park, which means the neutral switch and solenoid are ok; at the end you said you have to jump it at the solenoid. Which wires are you jumping at the sol?
There is no fuse for the ignition.  Maybe get yourself a 12 volt test light and look for voltage at the coil with the key in the run position.
mike
Sounds like your solenoid is shot.
Pinto Pro
My Pinto will crank over in park or neautral, but it wont start. Something is not letting the ignition juice thru to start the engine.
I think the neutral safety switch is working correctly because like I said, it cranks in park or neutral, but prevents cranking in reverse or forward gears. So I think that part is doing what its supposed to.
So what else can it be??
Ignition switch?? Solenoid??...is there an inline fuse somewhere (fusable link) that could possibly gone out??
Right now I can turn the key on and I have to jump it at the solenoid to start it, but it wont start with the key...help!!
