1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
74 hood
Date: 07/03/2017 03:46 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 09/09/2018 03:22 pm
Date: 09/10/2018 10:41 pm
Date: 02/28/2018 09:18 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 05/15/2022 11:36 am
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
  • Online today: 600
  • Guests: 545
  • Total: 545
Auto Dimming Mirror In A Pinto?
Started by dave1987, October 27, 2010, 09:16:40 PM
78txpony
These types of mirrors are usually made by two companies - Gentex and Donnolly.  Wiring should be somewhat standard to each make.
The electronics in most of the late 90s to mid 2000s are all in the mirror.  at the minimum you would need switched 12V for the dimming function.  Constant 12V will be needed for the compass cal settings.  There may be other connections, like a reverse light input to disable the dimming in reverse, thermistor input if you have temperature display, etc....
I have a mirror from a 96 Caddy that may make its way to the Pinto, as I want a nicer one for my Olds convertible.
That caddy mirror has the compass in it, too, so i will not get lost on my routine way to work...  :rolleye:
Here is my thread on the Olds board that may give you even more info!
http://classicoldsmobile.com/forums/electrical/12966-fancy-gm-inside-mirror-sources.html
If you get a gentex mirror, I have a wiring pinout that might help ya.
-Rob Young
1997 H-D Sportster
earthquake
I'm doing one from an Areostar. I think that it's all in the mirror,Is yours 3 wire.
How could I go about this? My idea is to get a good mirror from a 90's Lincoln Town Car with the auto dimming function and wire it up in my 78 Sedan, but, how do-able is this? The 90's Lincolns have the lighting/glare sensor unit as part of the mirror, is this all of the electronics I would need aside from connecting the mirror to a power source?
