Date: 09/01/2017 11:58 am
Date: 02/05/2020 11:06 am
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 05/24/2020 08:19 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 12/26/2016 04:29 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
  • Online today: 403
  • Guests: 245
  • Total: 245
Rear Engine Seal
Started by jeeprunne81, October 10, 2010, 08:46:49 PM
wedge446
Quote from: jeeprunne81 on October 10, 2010, 08:46:49 PM
Hey guys I need to know if it is possible to drop the oild pan on 1980 2.3l .  So I can drop the rear main bearing and change the rear seal.     Looks like it will be a tight fit.  I hope the rack and pinion doesn't get in the way.  last time I did it I had the engine out hoping to avoid that.  Help me refresh my memory so I am prepared to get this thing from leaving puddles in the drive way.
Just in case you really need to know.
75 wagon 2.3
I removed motor mounts(not needed) just to get extra room
Jacked the motor up as far as I could
Removed starter
Rack and pinion had to be removed to get the oil pan off.
There is enough room to replace the rear main seal.
I had trouble getting the rack bolts out, the bolts are rusted to the sleeves in the bushings. 2 came out with some WD40 but 1 of the sleeves was/is rusted too bad. I will have to cut the sleeve off the bolt.. Be careful of using the BFH, The sleeve punched through the frame..I will need to weld that up.. I got into a rush with it.
Everything else came apart ease.
Now I had to remove the motor, I found water/coolant coming from number 2 cylinder. Either cracked head, block or bad head gasket.. Im thinking head gasket. Now I know where the coolant was going.. I removed a few rod and main caps and the bearings are worn out..
Now the wife cant stop me from finishing the turbo motor :)
wedge446
I haven't done it but been told you have to drop the rack in order to have enough clearance to pull the pan. Disconnecting the motor mounts and lifting the engine is not enough. I have 1 pinto with the same problem, tried to get the rack free and no go... I have to pull the motor to change the rear seal on that one.
jeeprunne81
1980 pinto
1978 pinto
jeeprunne81
1980 pinto
1978 pinto
