Date: 07/30/2020 11:45 am
Date: 05/13/2021 05:33 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 03/23/2018 09:23 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 06/07/2021 08:14 pm
  • Online today: 169
  • Guests: 92
  • Total: 92
wagon hatch latch
Started by flash041, October 07, 2010, 03:45:37 PM
77pintocw
Hey flash041:
That's great, glad you were able to unlatch it without taking
the bolts out from the top.
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
I had to do that once (take the bolts out from the bottom) when something happened. Cant remember what it was but it was a patients tester LOL!!!
flash041
there was enough room at the bottom of the hatch to unblot the two latch catch bolt from the inside.
77pintocw
Hey flash041:
Same thing happened to my CW several years ago but fortunately
it happened when I was opening the hatch and the small metal
part broke on the other end of the lock after it was opened.  The
only thing I can think of without tearing up your hatch is to go inside
your wagon and take the bolts out of the hatch at the top and then
lean the hatch outward.  Then you should be able to get to the
latch and undo it from the bracket.
Good luck!
77pintocw
flash041
I went to open my wagon hatch yesterday and the key just spins. The small lever atached to the end of the lock cylinder either fell off or broke off. How can i get the hatch open with out mangling it up. I tried geltly prying and looseing the mounting bolts. Is there an easy way to do it with out destroying any thing?
