1979 hatch needed
Date: 05/13/2018 08:52 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 08/09/2018 11:09 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 06/30/2018 09:48 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 09/20/2018 11:01 pm
  • Online today: 586
  • Guests: 230
  • Total: 230
5/16 nutsert install tool needed
Started by hellfirejim, September 29, 2010, 05:45:10 AM
Thanks Fred, I appreciate the effort.  I will give them a call.
peace
Jim I checked there only listing up to 10-32, but you can give them a call they may direct you right.  1-800-831-2949.  Fred   :)
Jim mine are 1/4" down to 6-32 thread, but should be able to purchase at aircraft store. I will check my catalog to see if they have larger. I use to do major airframe rebuild but on light aircraft. Fred
That's them alright.  When you install them they tighten up like a rivet but threaded.  Are they for sale????
Is there a 5/16 in there??
These are used where you want a threaded nut on metal but there is no acces to back side. They swell like a rivet. Come in different thread sizes. They also have flush head were you countersink metal.  Fred   :)
soo talk to me Fred.  these are 5/16 bolts but I am willing to look.
PM sent.
Sounds like aircraft riv-nuts. I have a whole kit of those with 2 different pulling tool's.  Fred
Mike Modified
A little more involved but should work better if you're having trouble:
http://www.318ti.org/notebook/nutserts/index.html
I tried that, perhaps i need to try it again????  maybe i was doing something incorrectly.
thanks
DBSS1234
I have installed them with out the tool. Use a 5/16 bolt and a nut. Thread the nut up the bolt all the way, thread the nutsert onto the end of the bolt. Put the nutsert in the hole and run the nut down to compress the nutsert. you may need a washer between the nutsert and the nut to act as a bearing.
I am not sure if this is the right forum to post but I am puttting in a fuel cell in my Pinto and i need a 5/16 nutsert installation tool.  I have 4 nutserts to do and the tool cost about $100.  Anybody got one to loan?  or know where I can buy one at a better price that works???
peace
