1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 02/14/2018 01:34 am
Date: 04/10/2017 07:30 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 02/11/2020 12:09 am
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Date: 09/09/2018 03:22 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
  • Online today: 437
  • Guests: 424
  • Total: 424
7.5 inch clutch?
Started by EP73Pinto, September 06, 2010, 01:40:10 AM
EP73Pinto
This flywheel looks like a Cosworth 9 bolt flywheel with 6 long slots around the outside. It has a very small contact area that looks like it would only fit one size clutch. I don't think it could be drilled to take an 8 1/2 inch clutch because the clutch wouldn't have any place to hold on to.
The eBay seller says they have a resource for the 7 1/2 inch clutch assy, but they are slow to communicate. I'll post the results when I get them.
Its very easy to redrill most flywheels. Most new ones have both bolt patterns. Any machine shop can do this.
EP73Pinto
Quote from: Fred Morgan on September 09, 2010, 11:32:28 AM
I have 7 1/2" for 1.6 and 8 1/2" for 2.3.  Fred
Thanks, that helps a lot. I can search for  a 1.6 liter clutch.
EP73Pinto
The factory pinto clutch is a 8 1/2 inch, I need a 7 1/2 inch. This makes it difficult to search for one because most sites search by year/make/model which doesn't give you results for aftermarket parts. Has anybody out there used a 7 1/2 inch clutch or know of a good resource for one? I'm prett sure they are used in circle track racing, but I don't know anybody from that scene.
EP73Pinto
I just won a ~8 lb flywheel on eBay. The description said it takes a 7.5 inch clutch. The only place I can find a 7.5 inch Clutch is Racer Walsh and I cannot afford $679. Does anybody now where someone could find a clutch at half that price or less. The car will probably never reach 200 hp so it doesn't have to be a real high torque/hp unit. Thanks.
