1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 02/14/2019 06:27 pm
Date: 10/04/2019 08:43 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Brake rotors
Date: 03/24/2017 09:02 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 08/09/2018 07:49 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
  • Online today: 367
  • Guests: 123
  • Total: 123
Ranger Rear End
Started by MacGyverPimpo, February 27, 2005, 10:42:55 AM
I agree, the pinto/bobcat 8inch rear is the easy way to go IF you can find one, and the mustang II rears will fit too. If you are planning to do a brake upgrade in the front, like me (granada 5 lug), a 5 lug rear is what you need. From what I have been told, the 8 inch is better then the 8.8, but most of them will not be a direct bolt in. If you can do the engine swap, you should be able to mod the rear to fit. I am working with a 60's stang one right now, not bad, got it figured out, just have to finish it. Whatever you use WILL be better than the stock 6.75 rear.
dirt track demon
Quote from: TIGGER on February 27, 2005, 11:43:08 PM
The easiest solution would be to use an 8" from a V6 Pinto or Mustang II.  They are a bolt in swap.  Good luck...
I agree with tigger. As far as 8.8 inch ranger rears I believe they are only available in the later 1990's rangers or explorers. You would have to relocate the spring perches, and they are wider than a pinto rear.  Plus it might look a little odd with 5 bolt wheels on the back and 4 bolt wheels on the front.  not much room in a pinto to begin with, without hauling 2 spare tires! lol.
Anyway the 8 inch rear is going to be a lot tougher than an 8.8".
The 8 inch rears were offered as an option for some 4cyl pintos and bobcats as well.  Im not 100 percent sure but i think the spring perches were different on the mustang II 8 inch rears.    Uhhh I believe there is some info in the pinto FAQ section of this site as well.  Happy hunting.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
MacGyverPimpo
Also, one thing, if i do need to use a ranger rear end, what year of ranger and what model? a 2.3L a 3.0L a 4.0L? thanks everyone!
MacGyverPimpo
Hi,
I was told to use a ranger rear end when building my pinto with a 302? I was also told that they are 8.8  rear ends? is this true? will it work? and would it be sufficient?  If so, do i have to modify the rear end at all? I don't want to have to chop the rear end, i was hoping there would be a less-hassle solution for a rear end for use with a 302 and a t5 tranny? any suggestions? thanks all!
