Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 12/31/2017 11:14 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 08/01/2023 06:53 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
74 pinto
Date: 09/11/2016 06:32 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 12/10/2017 01:14 pm
  • Online today: 500
  • Guests: 432
  • Total: 432
Rear axle out of alignment
Started by r4pinto, August 01, 2010, 03:31:04 PM
LOL, yea Tom you guessed right. I got the replacement spring from a hatch/sedan, so I think I will try swapping it around to see if that helps any. It couldn't hurt to try.
 I assume you replace the broken spring, not the axle as stated???  Is it possible to put the spring in reversed? The axle locator typically isn't in the center of the spring.  Or, did you get a wagon spring which I believe  are longer?
Anyway, just a few ideas.
Tom
I got my 77 sedan that I have been working on restoring & when I bought the car the left rear leaf spring was broken & caused the left rear to drift & hit the rear fender. I replaced the leaf spring & never thought anything of it, but noticed the left rear wheel is not centered in the wheel well. The right side is centered but the left is not. What can I do to fix this? How can I fix this? Any help is appreciated :)
