'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 09/09/2018 03:22 pm
Date: 05/22/2018 02:27 pm
Date: 07/30/2018 04:32 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
  • Online today: 1,137
  • Guests: 772
  • Total: 772
2.3 CYLINDER HEAD
Started by pintoperformance, February 26, 2005, 08:51:53 PM
CHEAPRACER
I can't tell if you got my PM, something keeps locking up, let me know.
CHEAPRACER
The roller cam is a direct swap as long as your roller rockers are the type to fit the older size valve stems, be carefull as the newest (somwhere in the early to mid 90s) rockers were for the thinner valve stems and will not fit. The newer "D" port heads are usable on the older 2.3 engines. The intake manifold has no problem mating up to the "D" shaped ports but if it's a performance build then I would use a newer Fuel Injected lower manifold and use an adaptor to mount a Holley 2 barrel. The older cam pulley will fit the roller cam. They also made a 2.0 ranger motor with different ports, I don't know much about that one. Click on my web link and you will see a close up of that cam installed.
pintoperformance
 ??? QUESTION: WILL A LATER MODEL (1991-93)MUSTANG OR (1987-97)FORD RANGER 2.3 CYLINDER HEAD FIT MY 1978 2.3 FORD PINTO ENGINE.  AND CAN I USE THE COMPLETE SETUP IE:ROLLER CAMSHAFT AND WILL I HAVE TO CHANGE THE CAMSHAFT SPROCKET??
THANKS IN ADVANCE
MIKE
