1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 05/22/2018 02:27 pm
KYB shocks
Date: 02/08/2017 07:09 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 11/29/2018 10:26 am
Date: 02/16/2019 10:46 am
Date: 09/01/2017 07:52 am
  • Online today: 600
  • Guests: 475
  • Total: 475
difference Pinto 2,0 (1970-1974) vs. 2,3 (1975-)
Started by Pinto_in_Cortina, July 28, 2010, 05:06:39 PM
Pinto_in_Cortina
@turbopinto72
Thanks for the link,
sad, there was a little hope that these will be interchangeable and that I don't need so much $$$
g
Nothing between the 2.0 and 2.3 will interchange as far as what you want to do.
You can stroke a 2.0 to a 2.1 or even a 2.4... :P but there is $$$ involved. So I wont take up much space here I will just post the link and you can read for your self.
http://www.turbosport.co.uk/showthread.php?138346-Pinto-Stroker-2-4
Brad
Pinto_in_Cortina
Hello all,
I'm new in this forum. I was searching for differences between the 2,0 and 2,3 pinto engine but I did not find detailed information about - sorry I'm not very familiar with the 2,3 engine
I 've a 74' Cortina with a 2,0 Pinto engine from Europe.
So far I got information it seems to me that the European 2,0Pinto engine is the same as the 2,0 that was used at the first Pinto's from 1970-1974.
Do the later 2,3 engine used in the Pinto have the same block as the 2,0 only with bigger bore and stroke to come up to 2,3?
Better Asking the other way:
Do the Crankshaft and Rods fits with slightly 2,0 oversize pistons into the original 2,0block?
Do both crankshafts have the same length?
If not is there any stroker kit for the 2,0Pinto engine available?
Thanks
g
