Date: 08/24/2018 02:50 pm
Date: 02/18/2017 05:55 pm
Date: 10/05/2017 02:26 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 11/05/2016 09:03 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 02/26/2017 03:22 pm
Date: 09/01/2017 07:52 am
  • Online today: 548
  • Guests: 314
  • Total: 314
How to: Remove Speedometer cable from instrument cluster.
Started by Shane198three, July 26, 2010, 02:08:56 AM
Maybe if I did that with mine years ago the cable would't keep coming unhooked lol
Shane198three
Got it removed, great fun... Squeeze it hard by hand, some pliers will work, but be careful not to break the plastic piece..
OhSix9
remove  the screws on the cluster and pull the radio bezel. reach in from an open radio hole. on the cable right at the speedo is a plastic clip that has to be squeezed to release it.    push the cable towards the speedo, squeeze clip and pull back to remove.   takes a little tinkering the first time.
OhSix'
Virgil to Sid
Shane198three
How would I go about removing my speedometer cable from the back of my instrument cluster? Just pull? Video anywhere?
