Date: 12/09/2018 11:35 pm
Date: 12/31/2017 11:14 pm
Date: 02/03/2018 11:28 am
door sills
Date: 03/14/2020 03:20 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 07/08/2017 08:53 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 11/11/2019 04:49 pm
  • Online today: 295
  • Guests: 217
  • Total: 217
2.3 into a vw vanagon
Started by ricco, July 23, 2010, 05:52:56 PM
ricco
Perhaps it is an outdated belief but I believe that hot rodding is not what carb you have but how many and honestly it comes down to that nostalgic look.
why not just leave it fuel injected then?
A harness out of a 91-93 mustang could easily be hooked into the VW.
Dunno how well it would work but you might be able to build some custom spark plug wires that Y off the dizzy and run to each cylinders 2 spark plugs.
ricco
i just think it will look cool and it is some what a challenge.
Any reason on why your so set on running all 8 plugs?
I can tell you right now the 8 plugs dont make it get better mileage or preformance.
The 2.3s in VWs are pretty cool seen it a few times and almost bought a 74 superbeetle with one the otherday if i can get the cash i prolly will buy it then ill turbo it.
ricco
I've wanted to do this swap for some time. I have a kennedy adapter and flex plate. I can use my vw starter but have to fab some motor mounts.  I'm going to convert to carb on the 2.3 I'll have to fab some down draft tubes for my webber 44.  I would like to use the 8 plug set up. (Maybe run a dizzy on one side and magneto on the other side like air plane engines) or the hemi's-- if anyone has any info let me know.
Thanks Ricco
