Pinto wagon Parts
Date: 06/23/2021 03:25 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 02/11/2020 12:09 am
Radiator
Date: 05/27/2018 06:07 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 02/05/2017 09:45 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
  • Online today: 367
  • Guests: 104
  • Total: 104
A Pinto a Snake and a Sewer Rat walk into a blender
Started by OhSix9, July 21, 2010, 03:58:31 AM
Outstanding, so how did you modify the dash cap ?
hobbit1games
GO! PINTO GO!
don33
Oh wow, somuch of your build sounds just like mine....  looks awesome man !
Fehrion_sit
ohsix9, how hard was the GM brake swap, rotors calipers from a Granada, how did you modify the knuckle?
PintoMaverick
Looks good man! Really like it. I hope to have mine back on the ground this afternoon when I get off work. I need 2 17x8 Cobra R wheels, where did you get yours? I can find them in 4 lug all day long but havent had any luck in the 5lug. BTW the 97 Cobra disc brake rear fit like a glove and the 17x9 w 275/40 17 tuck under the wheel well!
1974 Pinto trunk model, 2000, 4 speed. 1971 Maverick Grabber, 4.6 DOHC 98 Cobra engine, 5speed, Mustang II front suspension, 4 link rear.
DreamBean
First Off, WOW! I love it. Secound, Were at the shop the other nite knocking back a couple of cold ones with the crew when I told them the idea I had for the dash? (just joking) That dash is something like I was explaining to them what I am working on. They still want to have me committed. I think they were hunting a stright jacket. ANY WAY! I sure hope you show up at carlise next year. I am gonna take the laptop down to the shop and show'em. That way the guys in the white coats won't take me away. This wagon is insane.
Go Ford, Go Fast Or Go Home!
man thats awe inspiring work. love how you did the port holes
OhSix9
thanks for the comments so far.
Yes i have a disgustingly large fmic for it.   will go in place with the precision t3/4 hybrid that is waiting in the garage for the moates goodies to show up so we can start makin some power around here.
The goal of the car from the outset was to use all modern ford parts in the drive train  Additionally i did not want to use anything custom in the way of drive shafts or rear axles so when it starts breakin parts they are easy to come by.
here is a link to a fbook album with way more shots of the progress to this point. it should be public but if not let me know i will open it up or just send a friend request
http://www.facebook.com/?sk=messages&tid=1523739419355#!/album.php?aid=146267&id=703636569
OhSix'
Virgil to Sid
pretty sure hes gunna run a front mount or atleast i hope so the stock ford ones are junk.
Love how you modified the dash pad.
The again I love porthole Pintos with turbos.....
Are you going to use the Ford "interheater" style intercooler on this?
like i told ya before man it looks sick glad its running for ya!
78txpony
A very clever and good looking kludge!   Looks like it is still mostly Ford, tho -
Very professional workmanship, too.
That will turn some heads for sure when done, IF they can catch sight of it!
-Rob Young
1997 H-D Sportster
sweet ride...... youre gonna have fun with it.... the little turbo motors are amazing....
OhSix9
Aka. Project Pimpin' Pinto as it has been known from its inception.
after much toil and tinkering Here she is.  not done but running and has all the required stuff to pass a safety . Kinda Beta 0.76
http://www.flickr.com/photos/52231613@N05/4814267019#
Whats all in it...
1978 ford pinto wagon, 88 tbird long block, 86 pk merkur harness and computer integrated with factory pinto harness (parts in the mail to get me into the ecu so i can reprogram and go 80mm MAF) Inter cooler and big turbo sitting in the garage.
urethane everything up front. new ball joints tie rods and rack.  5 bolt granada brakes, gm metric calipers on adapters   7/16 spacers to clear the bearings with 98 17x 8 cobra rims on all 4 corners.  215/40s up front and 275/40's out back , 86 t bird t5 and a fresh clutch, used an 94 explorer diff and squeezed the rims in the factory wheel wells with a blond hair to spare. got new leafs made and then pulled one long one to adjust the ride height. (adding some bags to control the butt end anyways so the lost spring rate is not a big deal.) tied it all together with an aluminum drive shaft from a 97 awd explorer. Didn't even have to change the yokes on either end :)  boxed the rear area and dropped in an 8 gal fuel cell relocated the battery and left room for the throttle bottle .  Got the roll cage and sub frame connectors on the garage floor still to go in.  Major delays with bodywork prevented all the goodies from making the show this year.
Bodywise we gutted the cruising wagon panels, fusored and spot welded the skins to the car and smoothed it all.   Did some rust repair and shaved the marker lights out.   Eagerly awaiting for Map to be ready to ship his rocker moldings and spats.  Also inlaid the turbo coupe scoops into the hood and used a splash mold cut down 76 cobra scoop to cover the required hole in the hood.  Did a glass dash cap with boost and tach.
Tons of other stuff....     Much more to come.
Please browse the album.
http://www.flickr.com/photos/52231613@N05/sets/72157624549615822/
I look forward to some feedback from fellow enthusiasts.
OhSix'
Virgil to Sid
