Date: 02/14/2019 06:27 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 05/22/2018 02:27 pm
Date: 04/12/2017 08:15 am
Date: 03/06/2017 01:19 am
Built 2.0
Date: 10/07/2018 05:27 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
1973 Pangra
Date: 01/06/2015 02:19 pm
  • Online today: 238
  • Guests: 167
  • Total: 167
Same key
Started by flash041, June 12, 2010, 05:21:20 PM
Yep, Ford also only had a certain number of different keys. They were supposed to ship the cars to different areas but way back when I first started working for Ford, I was in charge of checking in the new cars and servicing them before they went to clean-up. I had to make sure the keycode tag with the keys matched the bill of lading for the car. Once we got two Fairmonts at the same time that had the same keycode.
I had a '69 Dart that would start with my '71 Demon key but not vice versa. They were nearly identical but the Dart lock was worn just enough to let the Demon key work. I heard somewhere that Dodge only had 77 different keys back then. Ford is probably similar.
apintonut
my 74 keys fit beentoad that came with out any
im fairly good with lock and can make keys fit other same brand car but i carry a set of lock picks with me at all time and they've paid for them selfs over the years with out advertising and tend to make people very happy i had them
occasionally well once i had a guy be an a$$ and say "so what u steel allot of car!" i just told him i help out allot of dumb a---- and we was welcome
Quote from: tonij1960 on June 13, 2010, 12:46:57 PM
That might come in handy if you ever lock your keys in your car :)  On my 78 wagon the old key broke off inside the rear door lock,so now I can use any ford type key to open it. The only problem is its so hard to turn,it twists keys up after a while. So I keep a `sacrificial` key on my keyring. I wonder if a blank would work and maybe be more resistant to twisting?
the passenger side doesn't work because it is used less and the pins are still sharp
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
ToniJ1960
flash041
So , today I took the Cruising Wagon to get some gas for the boat.As always when I was a the pump some one came over to talk to me about the car.I put the gas can in the back and drove home.When I got to the hatch I discovered I left the key in it at the gas station.I could not figure how I started the car without it.I then discovered that my key for my 93 Mustang will start the Pinto!! They are not exact but really close.The pinto key will start the Mustang , although it does bind a bit.The Mustang key will also unlock the drivers door, but not the passenger door or hatch.
