Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 10/25/2019 03:30 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 01/06/2017 11:42 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 06/12/2018 08:18 pm
Date: 08/02/2019 04:18 pm
Date: 03/06/2017 01:19 am
  • Online today: 2,457
Screaming Meanie!
Started by blupinto, June 04, 2010, 12:03:35 AM
My 76 did that when the transmission ran out of gear oil. The new transmission I put in it a few years back has leaked a little bit every since I put it in. It ran out on a long trip and was fine in 1st gear but you drop that thing into 2nd and MAN did that thing SCREAM. Filled it up with gear oil and its been fine every since. Good ole German 4 speed. How many things can be run totally out of lubricant and not be destroyed. :)
Is that what that is!? OK if it is... how difficult is that to fix? Incidentally, Meanie doesn't like going in reverse- her shifter jumps out of reverse every time if I don't physically keep the shifter in R. Happily she doesn't pop out of her other gears (yet). Is this connected? Also, now and then I can't get the shifter into gear at all. Funny thing is, when she's screaming her shifting is ok.
rctinker
1977 Crusin Wagon when I was 16
I can't stay on here long either... it's that time of the month again ::)  (Emergency Power Transfer test)  Yuk :P
Hi Dwayne! I'll try tomorrow. Got to go to bed in a minute or two.  ;D
Geez... that doesn't sound good!  (no pun intended)  PM Jim and I'll bet dollars to donuts he can tell you what's wrong!
Here's a weird problem for y'all!
Yesterday I took Green Meanie to work because my friend had bags of horse manure for my garden and Meanie was the wagon for the job. Going to work she was ok, but on the way back she made this screaming noise in the area between the back of the engine and the front of the transmission. Third gear is when the screaming starts. It sounds like a mountain lion being electrocuted, or neutered without anesthesia (not that I've heard mountain lions electrocuted or neutered!) She drives the same- no loss of power or difficult shifting. However, she is LOUD!!! The noise hurts my ears. Is it the flywheel? She is downed til it's fixed. I am calling her Screaming Meanie for now.  :(
