2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 07/21/2017 11:49 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 08/30/2018 12:59 am
Date: 12/09/2018 06:59 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 12/10/2017 01:14 pm
  • Online today: 344
  • Guests: 268
  • Total: 268
tailgate seal
Started by 78squirewagon, June 02, 2010, 06:17:48 PM
Will this work as a replacement for now? Also would anyone trust them for door seals ?
http://www.jcwhitney.com/universal-door-trunk-and-hatch-weatherstripping/p2008604.jcwx
Also, would anyone use these to replace the window channels. Mine are getting worn out and I need to replace them on all three cars.
http://www.jcwhitney.com/all-rubber-window-channels/p2009944.jcwx
77pintocw
Hey Pintopower:
By chance do you have a JC Whitney catalog number or some
other catalog number we can use to get the FORD FOCUS 2
Door door seals as a replacement for the tailgate seal.
Thanks,
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
THANKS!!  I will check them both out and go from there. The car does not come out in the rain that much but the last couple of weeks I have gambled with Mother nature and lost. Oh well, at least I know where the leaks are now. :)
Pintopower
First generation FORD FOCUS 2 Door door seals. The are a perfect fit. They also fir '77 and newer runabouts. Those are what I have used on all of my cars.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
JonzWagon
Hey Mark
  Two years ago i had the same problem with my '80 wagon. My solution was to get the DOOR SEAL rubber (it goes around the cab, door closes against it) for a 1999 or newer Ford Ranger PU. It has the correct profile, was less than $20 thru JC Whitney. Start at the bottom and go around to the bottom again, you will be about 4 inches too long. just trim it to fit. Make sure the seam is at the bottom, like factory. It was a perfect fit, no leaks since.
I am sure that this is a simple question but where can I buy a new tailgate/hatch seal for my wagon? After sitting and driving in a down pour tonight I found out that mine is leaking pretty good.
Thanks
Mark
