Date: 09/02/2021 08:21 am
Date: 11/14/2019 04:02 am
Date: 05/13/2021 05:29 pm
Date: 10/24/2019 01:43 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 11/08/2019 10:01 am
Date: 02/05/2017 09:45 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
  • Online today: 2,415
  • Guests: 2271
  • Total: 2271
back from the alignment shop
Started by dholvrsn, June 01, 2010, 12:52:53 PM
OhSix9
totally normal readings.   can be slight tweeks in the tubing or just the location the pads where originally welded on.  also if you look the diff is really located with rubber bushings that will have some give to them which can affect readings as well
OhSix'
Virgil to Sid
Just got Wee Beastie home from the alignment shop. I'm looking at their courtesy printout of what was done. I'm grinning and scratching my head over how the straight rear axle can have -0.4° of camber on one side and 0.1° on the other. Also 0.0° of toe-in on one side and -0.29° on the other. I'm guessing that it's sag and slop and wear on this old axle.
