Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 12/09/2018 11:35 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
free transmissions
Date: 11/28/2019 10:21 am
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 06/19/2018 03:58 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 03/17/2019 10:15 pm
Date: 01/10/2022 03:41 pm
  • Online today: 2,415
  • Guests: 2264
  • Total: 2264
Paint prep suggestions (sanding before paint in awkward area)?
Started by popbumper, May 28, 2010, 01:11:31 PM
I was thinking with the wire wheel... Dremel Moto Tools have lots of different heads for different jobs.
Oooh... do I sound like a commercial...? :o ::) ;D
Quote from: blupinto on May 28, 2010, 04:57:17 PM
A Dremel might help in the teeny nooks and crannies.
Not a bad idea, but it would probably be too aggressive - hard to scuff without cutting through to the bare metal with a dremel.
OhSix9
Timmay has it right
Red scotchbrite pad and go to town.
OhSix'
Virgil to Sid
Unless the primer just didnt lay flat i usually just hit it with a scotchbrite pad.
If you really are wanting the 400 grit paper in there just sand all the big open areas with paper on a block and the uneven nooks and crannys use the paper on your fingers try to stay away from edges as much as possible just lightly hit them enough so the paint has somthing to stick too.
That was just hit with a red scotchbrite and sprayed and it still looks the same now except for a couple spots where i hit it with the new header i put on it. LOL
Hi all:
  In the process of restoring the engine compartment on my wagon, getting close to the point of paint (it will be done separately from the rest of the car, I have alreday secured factory color spray cans to carry this out).
  Anyway, my question is this. Given that the engine compartment has all kinds of interesting folds/creases/nooks/crannies in the metal, the effort of sanding is somewhat challenging. Already primed, knocked down, and primed again in preparation for 400 grit sanding, does anyone have suggestions on how I might final sand without "breaking through" on edges? Is it just a matter of time and care? Do those "sanding sponges" come in a finer grit that will allow me to roll over the surfaces with less chance of cut-through?
Hoping someone here with experience can chime in. Thanks!
