Date: 05/13/2021 05:29 pm
Date: 08/05/2018 01:58 pm
Date: 01/24/2017 12:36 pm
Date: 01/19/2020 09:06 am
Date: 12/04/2018 07:40 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Racing seats
Date: 10/24/2019 09:41 pm
Date: 09/01/2017 07:52 am
Date: 11/23/2017 05:44 pm
  • Online today: 502
  • Guests: 473
  • Total: 473
2.0 performance problem?
Started by 72Wagon, May 16, 2010, 08:23:53 PM
All Esslinger intakes (2.0 & 2.3) run pig rich on the center two ports due to their short length in relation to the outside two ports. Not much you can do about it too.
72Wagon
I am having a strange problem,engine seems to have a engine miss but it is not a dead miss. I checked the exhaust temps (one inch out from head on headers) and the 1 and 2 are running at 500 degrees and 3 and 4 are runing 700 degrees.Temp range stays same at different rpm ranges.
The engine is running a 390 holley on a esslinger intake, .100 shaved from head, a pretty radical cam (can't remember specs off the top of my head),recurved stock bosch distributor (points), bottom end pretty much stock.
Any suggestions on what could be causing the temp between front 2 and rear  cylinders? Car runs good otherwise.
1972 Wagon
