78 windshield trim
Date: 02/01/2020 08:46 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 01/10/2022 03:41 pm
Date: 04/04/2020 09:38 am
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
  • Online today: 500
  • Guests: 285
  • Total: 285
Amp gauge in my '80 hatch always shows discharge
Started by Pinto5.0, May 15, 2010, 01:38:20 PM
78txpony
With the engine off, turn the lights on and see which direction the needle moves.
If in the same direction (to discharge), I suspect alt, regulator, or miswiring.  The latter can be eliminated if you did not modify wiring prior to this issue.
Yes, a weak ALT can cause this, too.  Let us know what the voltage checks at.
-Rob Young
1997 H-D Sportster
Im going to have to check it with a meter. I know its not backwards since it reacts normally but only on the discharge side. Im wondering if my alternator is weak & only putting out 12 volts.
RSM
Gauge hooked up backwards is the first thing I thought of....
78txpony
When did you notice the problem?  This sounds strange, almost as if the gauge is hooked up backwards (providing alt is working).   ???
Put a voltmeter across the battery to verify around 14V when running.
Common failure mode for ammeters is that the needle does not move or not enough. I never heard of them reversing direction.
I found that a Pinto will go a long way on a non-charging battery.  The only thing that signalled me that my alternator died was that the electric choke was not opening and the engine ran like crap.
Do check the alt. output, both with and without lights on.
-Rob Young
1997 H-D Sportster
I have the vent gauge set in my '80 hatch that has oil, amp & temp. I was going to use them for now with my basically stock 5.0 since they work fine. Problem is the amp gauge never goes right of center but it does show slight discharge when running & drops farther with the lights on. The battery never goes dead & the lights arent dim. Is this common with the stock gauge or is it junk?
