Date: 01/24/2021 07:54 pm
Date: 04/10/2017 07:30 pm
Date: 06/07/2021 08:14 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 06/30/2018 09:48 am
77 pinto
Date: 08/22/2017 06:31 pm
Date: 05/15/2022 11:36 am
Oddsnends
Date: 12/20/2016 10:52 am
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
  • Online today: 2,415
  • Guests: 2289
  • Total: 2289
Cruising Wagon bubble window insert molding
Started by flash041, May 12, 2010, 04:36:38 PM
flash041
your welcome! More info..there is enough on the roll to do 2 cars /4 windows.
Mike Modified
 :hypno:  Gotsta have it!  Thanks!
Mike  :afro:
flash041
Here are the windows with insert installed.It worked PERFECTLY!
flash041
I am paintin Friday and hope to have the windows back in this weekend. Ill see how it fits then.
Pintopower
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
flash041
Just order one. You will have LOTS extra.
DBSS1234
When purchasing this moulding do you only need to buy one part or two? Due to the small length needed per port hole window I assume only one but I want to be sure.
Thanks
flash041
Got the molding in today. Looks GREAT! Sorry the pics are a bit fuzzy.The left is original , right replacment. Other is with the insert in the rubber gasket. Looks like a perfect fit and match. ill let you know for sure when I install the windows.
Pintopower
flash041
I ordered the molding last night. Ill take some pics when I get it in and installed.It should be within two weeks.
Mike Modified
flash041
I found a source for replacment chrome insert molding for Cruising wagon bubble windows. They are idenical ( except the back side is flat not pionted} to the ones used on 1978 Bronco windshield moldings.I matched my old one up the the new onesa friend just got. He got it from broncograveyard.com . It is the same with and has lock edges like the Pinto's , like I said the back is flat , but I dont see why it wont work. Here is a link. http://broncograveyard.com/bronco/i-25180-windshield-reveal-molding-chrome.html
