1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 09/01/2017 07:52 am
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 10/05/2017 02:26 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 12/04/2018 07:40 pm
  • Online today: 361
  • Guests: 349
  • Total: 349
backfiring problem
Started by dcbchristian, May 12, 2010, 10:42:20 AM
If its a 2.0L, check to see if the points are loose from the plate they mount to.
CHEAPRACER
It takes a lot more spark energy to run an engine under a load. Something as simple as a break in a plug wire or retarded timing will cause a backfire under load. My advice would be to start with a complete ignition tuneup including new wires and make sure you set your timing.
dcbchristian
Since mine is a 72, I don't have a cat. I'm not running egr or charcoal purge canister. Then the next step is a 351w :)
I had a burned #4 plug and it backfired on decel, not acceleration. It's fixed now, but it used to pop back thru the cat or sound like it was detonating in the cat sometimes. Getting straight piped soon since no emmissions laws in my area (yet :-\). I just took off the air pump and blocked the hole in the manifold with a 1/2" MIP (male iron pipe threads) from Home depot. car runs a lot better now. EGR is next to go!
Chuck :coolafro:
Pangra74
Yeah, I agree with Fred. Mine used to pop back thru the carb....ignition timing was the culprit
Joe
1974 Orange Runabout
Is engine warmed up ? is ecelerator pump working properly ? is ignition timming to far advanced ? are valves ok do compresion check.  Fred   :)
dcbchristian
when i get on the gas hard, my car backfires. any ideas why?
