Date: 10/01/2020 02:00 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 09/12/2018 04:07 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 02/27/2017 10:10 pm
Date: 08/02/2019 04:18 pm
  • Online today: 586
  • Guests: 130
  • Total: 130
Project "Merc-Runa-faux"
Started by Pintopower, May 06, 2010, 01:24:33 PM
looking better all the time  i will get the pic  for you when vacation is over
chrisf1219
great work as always alberto. looks really good istill think i should have let you fix my wagon up insteed of me. ;D   see ya chris
Pintopower
R4 Pinto - Yes the wood will be back on soon.
So the trim is all back on! Every inch has been all polished and repaired. The interior is all in minus the new dash and the recovered front seats (to match the rears). It is looking great and running great. You will also notice i ditched the full size spare in favor of space saver so that I could have a flat load floor instead of the ridiculous hump that the standard cars have. The door panels were cleaned and painstakingly masked off. Then I prepped and dyed them. They are slowly puffing back up as they have had stuff on them. The windsheild rubber was changed as was all the rest of the rubber in the whole car. I can't wait for the seats and the dash to go on! Plus the wood and wheels will finish it all off.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
Looking really good! Are you going to have the wood grain back on the side of the car?
sure they would  send me a pm  they are mine. having computer problems at home  and from work i can not start a pm but can reply to them
Pintopower
Thanks Dwayne!
Phil, would they be interested in parting with them? Send me a message with contact info if they are.
Bigtimmay - Because mine is a "Villager" hatchback with the wood decals, it did not have the rocker molding. As for above the quarter window, do you mean the drip rail? Mine had it but it was plastic and badly deteriorated. I have stainless ones for it.
Humm i just noticed my bobcat has some trim yours don't. Mine has the rocker trim and a piece of trim that goes across the roof right above the quarter windows. Was that just something they added to the newer ones since mines a 78?
I kinda like yours since it doesn't have them. If i paint it again i might just remove those and smooth it out.
looks good  i know some one who has a set of mercury centers  but they are pitted and just dont look right  on white rims with the red stripe
:look:
It's really looking great!  Keep up the good work!
Pintopower
Some more updates, I have gotten Freddy's passenger compartment carpet and load bay carpet done. It was dyna-matted first and then a layer of recycled padding went over that. I did the head liner and visors (my Fiances' dad did them) plus made a steering wheel for him. The rim is cracked so the next thing is vinyl wrapping and to have the front seats done to match the rears with the correct brown plaid Merc. interior. The car has all new door and window seals from Greensales (the only place you should get anything Pinto from BTW) and next weekend I will be assembling the doors. The seatbelts were rewebbed at Ssnake-oyl.com in Texas and the Dash (which i need to install) was redone at Just Dashes.  Wood painting will come when my sister is back home from PA. The car will be getting the factory Ford mesh forged wheels with mercury wheel caps.
Pintopower
Thanks, I still have a lot of hard work ahead of me but the car will be done and presented at the 2011 All Ford Show in SoCal
its top notch work man it looks amazing.
Pintopower
75bobcatV6: No i just polished the center chrome piece and painted the rest argent.
Tigger: The hatch pinchweld was modified to be like a 77-80 pinchweld. The difference is that the 71-76 have a lip that allows the gasket to be installed from the top rather than the side. If you slice that off you will be able to use a ford focus seal like you can use on the wagon hatch. It is nearly a perfect fit. Hosed it down and there were no leaks.
dga57: Thanks!
Looking good! :surprised: :hypno: :surprised: :hypno: :surprised:
Alberto, did you replace the hatch seal or are you still using the original?  The one on my 78 glass hatch has shrunk some so I had to seal the lower corners to keep it from leaking.  Just curious to know what you are using.....
Did you have the Grille Chromed? it looks Awesome.It all Looks so so nice.
Pintopower
So now Freddy is home so I have begun to reassemble him.
From a 76 standard hatch to an all glass:
Next is the lumber. The headliner is ordered, the seat belts are at ssnake-oyl and all the rubber is on the shelf. All the trim has been redone and i have bushel of clips waiting to be painstakingly installed.
Wish me luck.
Pintopower
And here it is painted. Just in time for me to notice that Tigger has a roof for me.
Pintopower
Well all the body work has been done. The roof rack was ditched since it caused EXTENSIVE rusting to the roof. The hatch area was modified and the pinch weld changed to the 77-80 style.
Pintopower
Quote from: TIGGER on June 10, 2010, 08:33:36 AM
How about a factory crank back sunroof?  I was going to cut the roof off anyway before I scrapped the car.  Not sure how I would ship it to you though....
Gerhard and Alberto line me up with enough part's moving south to north eye-5 to cover fuel cost only I will deliver that roof. Also any part's going either way including a car or furniture.  Fred
Quote from: Pintopower on June 09, 2010, 03:59:40 PM
Oven cleaner and putty knives. The oven cleaner greatly softens the old hard vinyl.
Dave1987, the paint is after I get a new roof on the car....
I NEED A MOONROOF ROOF somebody!
Any specific brand? and your a life saver, and an Arm saver lol. Have putty knife need to get the cleaner now =)
Pintopower
Well save all the A/C goodies, i'm sure someone can use them.
good to know since ill never be putting the a/c back in my car itll be one more thing gone t so thats a couple more ounces off the cars total weight LOL
Pintopower
The sensor is for the A/C system. It is a temp sensor. Sadly, I know little of what if does.
In the picture of the power steering cooler what is that sensor thing below the hood latch my bobcat has it too and i havent had time to figure out what it is or if i need to move it somewhere else cause its in the way for where i want my intercooler LOL
Pintopower
Smells like progress, a big step in the restoration is about to take place....paint! :D
What did you use to get the woodgrain off? I used many razorblades. and Better ideas? lol
