Electrical
Date: 03/29/2017 11:37 am
Date: 04/07/2021 06:12 pm
Date: 07/01/2019 03:17 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 01/20/2018 07:51 pm
Date: 11/12/2020 08:28 pm
Date: 03/16/2017 10:00 pm
Date: 02/25/2017 08:45 pm
  • Online today: 628
  • Guests: 521
  • Total: 521
Door panels....where did you get these done cookieboy
Started by 302PintoMan, May 05, 2010, 12:32:22 AM
cookieboy beat me too it but ya those are super simple to make.
Either use the stock cardboard panels or make new ones out of a thin sheet of wood use some thin foam cut it and layer it how you want it to look then glue the foam to the door panel.Cut a piece of material about 2 1/2 inchs larger then the panel all the way around  using spray glue glue the material onto the door panel streching and pressing it onto all the layers so your raised design comes out smooth and not wrinkled and once the front of the panels all glued just wrap the excess material over to the back and glue it.
This is the same process used in making fiberglass panels too with the exception that instead of using watever material you want you have to use fleece then once its all glued and looks how you want it you use fiberglass resin and a brush and brush it over it. Fleece absorbs alot of resin so youll need to put prolly 6-8 layers once the resins cured you can sand it to knock off most of the bumps in the resin if there are any then skim coat it with some body filler and sand that smooth then prime it and paint with your choice of color and paint scheme.
Working at a stereo shop had its benefits.
Tony made them himself as I recall... made a door panel, carved the shapes from foam and used meterial of choice to cover.
Im sure cookieboy can tell you where maybe. but the source would be best. his name is Pintony. Maybe cookie can call em up for the number of the shop he used =)
302PintoMan
I was looking at this http://www.cookieboystoys.com/friends/purplepinto.htm and dig the hell out of the door panels.  Where did you get them done and can I get them done for the 75 wagon I have?
a true hot rodder wouldn't be content until he had created a car so violent, so hairy, so totally sick, that the very act of pressing the throttle, could result in instant death
