1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 01/19/2021 03:56 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 01/28/2021 03:49 pm
Wheel cap
Date: 04/25/2022 11:21 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 08/09/2018 07:49 am
  • Online today: 531
  • Guests: 186
  • Total: 186
73 2.0 backfiring through carb help
Started by pinto_chris, January 29, 2005, 06:43:26 AM
Quote from: pinto_chris on January 29, 2005, 06:43:26 AM
the 2.0 in my 73 is backfiring through the carb and is really hard to start, as well as intermitintly haveing a major drop in power, i've tried putting a rebuilt carb on it but that didn't help for long, also the timeing jumps around when i check it with a light. thanks a bunch chris
This is typical behavior of a  timing belt issue. One tooth off and it will cause your car to do all the above.
allfordmark
I would also check the distributor mechanically.  As well as the distributor drive gears and wheels.
'66 Mustang
'72 Pinto
'50 F-1 1/2 ton Pick-up
Tobey
Sounds more like an ignition problem.  Do you still have points?  Try new points, cap and rotor, and spark plug wires.
Poison Pinto
Check the timing belt to make sure it's not slipping. It may be a worn belt or a worn sprocket.
pinto_chris
1973 ford pinto wagon
1966 amc rambler
1985 Mercedes 300 D, powered by used vegtable oil.
  hey I like being different! stop laughing now damn it or I'll sick the penguins on you !
