Date: 04/21/2017 02:03 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 01/28/2019 05:15 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 01/06/2017 11:42 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 10/02/2017 02:16 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
  • Online today: 2,670
  • Guests: 574
  • Total: 574
ford 8 inch swap
Started by dcbchristian, April 29, 2010, 03:00:14 PM
Hi dc,
The spring purches will need to be moved outward if I remember right and keep in mind the rear is about an inch narrower so wheel offset is effected. I like the deeper offset of the rim in the back myself and almost went the same route but decided to stay four lug because I'm only putting 130FT LBS of torque through the 8 inch I lifted from a 76 Pinto. A 1 inch shorter drive shaft my be in order also if you are staying with your shock tranny.
dcbchristian
i have an 8 inch from a 74 maverick. 5 lug pattern. what has to be done to it to fit under my 72 pinto? thanks!
