Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 08/20/2017 01:34 pm
Date: 03/06/2017 01:24 am
Date: 02/28/2018 09:33 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 02/18/2017 04:44 pm
Date: 02/08/2018 02:26 pm
  • Online today: 548
  • Guests: 283
  • Total: 283
Alternator wiring help PLEASE!!!!!
Started by 302PintoMan, April 26, 2010, 02:18:51 PM
There is also tuner/contact cleaner. But that stuff isn't cheap any more either. Also sometimes works on noisy radio pots.
302PintoMan
Picture helped a ton, charging like a champ thanks a ton. But now the damn headlight switch took a dump.  Dash lights and tail lights only work if your jacking with the switch.  Hope they sell those at O'riellys.
a true hot rodder wouldn't be content until he had created a car so violent, so hairy, so totally sick, that the very act of pressing the throttle, could result in instant death
blink77
Mike is right on. That is exactly how I wired mine, I just didn't
have a picture. Nice-neat job Mike.
Mike Modified
The yellow hot all the time:
Green /red switched positive, NOT start, but run.
302PintoMan
ok so the 2 colored wire needs to be to a wire that is hot ONLY when starting the car?
blink77
Big yellow wire is hot all the time. I ran it to the hot wire
stud on the alternator on mine. I just did this a couple of
weeks ago, and it has been working fine. I checked this
out on my 01 Ranger before I did it. I don't know where it
gets its power from on the Ranger, but I know it is HOT all
the time. I think I may go back and put a fusable link in as
I think it may be on a fused circuit on the Ranger. For sure
it is HOT all the time, as is the wire on the stud, witch goes
directly to the BATTERY. The green/red stripe wire goes to
the exciteter and needs to be HOT when the ignition is in the
run position. It's a real simple system and works really well.
Sorry to be so LONG.
302PintoMan
Ok I am going from external regulator to an internal regulator.  I got an alternator for a 95 Mustang.  I have the red wire that runs to the solonoid for battery feed.  Got the plug at a wrecking yard for free but they told me it was free because they want to see the car.  LOL.
Ok here is a pic of the plug I got just need to know what goes to the big yellow wire?  Hot when key is in run position or when in starting position.  The little one I believe goes to indicator.  Below is pic of alternator and the plug I just got.
Robert
903-487-8657
