Date: 02/21/2017 06:29 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Date: 12/09/2018 06:59 am
Date: 04/24/2018 11:45 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 05/13/2021 05:33 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 12/31/2017 09:03 pm
  • Online today: 2,535
  • Guests: 2331
  • Total: 2331
Rear ends in Mustang II's
Started by rctinker, April 26, 2010, 12:41:46 AM
I've seen a Mustang II in a boneyard with a factory 6-3/4. So they're out there.
rctinker
Awsome, thanks Wittsend, Tigger and Fordstuff.
1977 Crusin Wagon when I was 16
fordstuff
Look at the rearend from behind the car.  If you see bolts holding the cover on the center of the rearend it is a 6-3/4".
It is similar to the image that has the #4 in it.  I couldn't find a 6-3/4". It is a 7.5", but the bolts on the rear are very similar in concept.
  If the center is smooth (no bolts) it is an 8". This is the image that says "the Hump").
  Very simple and straightforward.
rctinker
any body have any pics of the rear ends, the 6 and the 8 so I know what I am looking at.
Thanks, Tink
Quote from: rctinker on April 26, 2010, 12:53:21 AM
So a stang II with a 2.3, 4 speed would probly have the same rear as a pinto?
Thanks, Tink
Most likely unless someone changed it.  Do like Fordstuff said and see if it has a removeable carrier.
fordstuff
well best way to tell is crawl under it i think. if its a drop out center gear section its an 8 inch. if it has the inspection cover on the back its the pinto stye. 6 3/4" i think.. i pulled one out of a Mustang II saturday . it was a v6 4 spd. and it was an 8inch but not posi. roy
Thanks, Tink
rctinker
Thanks, Tink
Certain models, V8's for sure and I think most V6's.
rctinker
Did all Mustang II's have the 8 rear end in them or was it just certain models?
Thanks, Tink
