Oil pan front sump style
Date: 01/10/2017 09:19 am
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 04/28/2018 04:12 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Date: 10/25/2019 03:30 pm
parts needed
Date: 02/20/2017 07:58 am
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
  • Online today: 600
  • Guests: 475
  • Total: 475
hatch light problem on 79 wagon
Started by dmsteen, April 16, 2010, 10:47:51 AM
Dave when the add run's out next month I will have the wiring. Funny wire in this car goes to left side not right.  Fred   :)
                infact I have the whole car to part out  ;D
dmsteen
thanx everybody! as i just found out mine does not have the wiring so if anybody has it i would like to buy it.   thanx  dave
TIGGER is correct. I pulled the light and wiring from a 78 bobcat wagon at the junk yard last year. It runs along the inside of the passenger side quarter panel(s), under the carpet hold down trim, and (on this specific car I parted out) it also splits to connect to the passenger side door switch for the dome light. All this wiring then leads to a connector above the glove box in the dash.
I only initially wanted the wiring so I could have dome light switches on both doors of my 78, but I ended up pulling all of it to ensure I didn't get lost i the wiring somewhere later on.
No my knowledge, the wiring is not there unless your wagon has the option.  I pulled the wiring from a car in the wrecking yard years ago.  If I remember correctly, it ran all the way up to the dash along the pass side.
Maybe maybe not. Check in the corner.  Fred    :)
dmsteen
so the wiring runs accross the roof? also will the car have the wiring there even if it did not come with light?
Dave this is 78 Bobcat 3 wires. Ground blk.  positive blk. with blu tracer  pos. lt. grn. with ylw tracer  this light has switch.  Fred   :)
dmsteen
i went to put my new hatch light in and...no wiring there and then i noticed the wiring to the buzzer was cut off. i looked in my electric book but not much info on wagons.any suggestions on how to hook them up before i start taking everything apart   thanx  dave
