Date: 03/17/2019 10:15 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 10/25/2019 04:05 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 01/18/2017 05:35 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
72 Pinto
Date: 03/07/2019 12:07 pm
  • Online today: 481
  • Guests: 151
  • Total: 151
2.3L serpentine conversion
Started by jimdaug, April 10, 2010, 01:21:39 AM
jimdaug
Resurrecting my thread,
I know this is a little delayed, but I in May I herniated a disc in my back and ended up having to have a discectomy, so I've been down and out for a while.
I'm doing much better now and I'm finally installing my serpentine pulleys, and I had read, but forgot until I tried to put the water pump pulley on, that the hole needs to be enlarged to 3/4".
How precise does that hole have to be? Do I need to go to a machine shop and have them bore it out, or can I grind it with dremel or die grinder?
Thanks for any info,
EDIT:  I searched a little bit and found that Pangra74 had done the conversion so I PMed him and he said he used a stepped unibit type drill to enlarge the hole and hasn't had any problems. That sounds like it should work well since the bit is short and stiff and the steps will keep the bit centered.  I'll give it a go and report back.
James
jimdaug
Ah, no prob.  I thought maybe I had missed something and stuck my foot in my mouth. :lol:
Mike Modified
While reading your question, I clumsily passed over the word "pulley", hence my first response about water pumps.
The whimsical part of me thinks that the cited website could help my poor reading skills.  8)
jimdaug
Mike Modified
Quote from: jimdaug on April 17, 2010, 10:57:25 PM
Nah, just need the pulley.  Although it might not be a bad idea just for maintenance sake.  I'm guessing the 5.0 liter pulleys won't work either. There was a set of those on ebay for like $20.  I'll just have to get to junk yard one of these days.
Note to self: spend at least 30 minutes daily here: http://www.rif.org/
jimdaug
wow 24 bucks rebuilt they are only 15.99 at oriellys new is 32.99 im glad we got oriellys here lol
Mike Modified
3.0 won't fit.  If you need a water pump, they are readily available new or rebuilt.  Rebuilt at Napa is around $24.00.
jimdaug
would the water pump pulley off of a 3.0L work? I found one on ebay for $15 i haven't had a chance to go junk yard diving yet.
jimdaug
That's ok Fred, there's not enough room for the pump and I don't want to mess with running lines for it. I probably will be adding an electric fan at some point.  Right now I just want to get the thing running again :).
EDIT:  Pictures!!!!  They're not great, but it'll give you an idea of how cramped everything is.
Joe got the power rack from me out of a 78. I have an 80 availiable if needed.  Fred   :)
Pangra74
I'm running a serpentine conversion on my 74 2.3. I also added power steering to mine. Got the parts from a 93 Mustang if I remember correctly. The only thing I had to do was open the hole a little in the new water pump pulley as the newer water pump has a smaller shaft size. Works great with a Spal 12" electric fan.
The stock air cleaner can just fits behind the alternator.
Joe
1974 Orange Runabout
Some of the AC duty fans have large blades that angle back.
jimdaug
Clearance shouldn't be a problem.  There's a 2in spacer on the water pump pulley right now.
There is also the problem of fan clearance, especially with the original '70s Pinto fans.
jimdaug
Oh yeah, it scoots with the stock motor in it.  I can't help but think it's a deathtrap as small as it is, but that makes it exciting :)
Yup i know wat a gazzelle kit car is there was a guy around me trying to sell one for some time i think he wanted 2500 for it i always thought about trying to stuff my 2.3t under the hood of it but when i looked under the hood i was sad to see how little the space there was. Sucks too 300hp 2.3t  in a 1800 lb car woulda been a great time. haha
jimdaug
@Mike, Hah, that's different.  The only reason I wouldn't go for that is that the alternator I have is practically brand new from P&A Performance. I think that the crank and pulley info from your link should get me there tho.  I'll see if I can snap a picture while I'm out there tomorrow and maybe there'll be an even better solution.
@Bigtimmay, its called a Gazelle. It's a 1929 Mercedes SSK replicar.
It actually became somewhat of a nightmare for me and my dad a couple of years ago.  The windshield motor wrapped some of the wiring behind the dash switches up into it and we didn't realize it.  The garage we used to go to tried to fix it, but it still didn't quite work right so he told me to go ahead and put a whole new wiring harness in. So over the past 2 or 3 years ( I can't remember any more) I put a Painless harness in with the fuse box in the trunk, and took the A/C and Heater core out because it wasn't even hooked up. I also put a 3G alternator on it and fixed/removed some of the other kludges like coffee cans that were use as vent outlets, and banished the wiper motor over to the passenger side where there is no wiring to get hold of.
I'm getting pretty close to being done tho. :lol: I had to replace the fuel pump today because it decided to start spitting gas out of it. We're gonna hopefully get it to an upholstery shop in the next month or so.
Mike Modified
Here's one way to get the Ranger alternator to the passenger side.
http://forum.merkurclub.com/forum/viewtopic.php?t=12217
On a 2.3T it looks, with the Turbocoupe powersteering on the driver's side, like this:
crank pulleys should be a direct swap and as for the powersteering pump not clearing alot of the 2.3 rangers didnt come with powersteering.
What kinda kit cars this motor in?
jimdaug
Thanks for the info, Fred and Bigtimmay.  I didn't realize that setup was around for that long.  There should be plenty of early 90s mustangs and or rangers around me. The only issue I see is that the power steering pump gets kicked way out to the right there. It's a pretty tight engine bay.  I'll snap a pic if I get a chance.
But, It looks like maybe I just need the water pump and crank pulleys.
Did the crank pulley go on without any trouble?
89-92 rangers with the dis motor have serpentine setups too
This is out of 93 Mustang has power everything.  Fred   :)
Look for a 2.3 T-Bird Turbo Coupe or Mercur(sp?). They had serp belts.  :)
jimdaug
I have kit car with a 74ish 2.3 liter ford motor in it and I'd like to change it to serpentine, because the single v-belt is a really tight squeeze to get on the crank pulley.  I can't really get a longer belt either, because the alternator would then rub on the driver's side of the engine compartment.  Also the single v-belt will squeal because I think it's too much for it to spin the 3G alternator that I put on.
So a few questions
Will 5.0 liter mustang pulleys fit, or am I going to have to scrounge up an 80s model LX or T-bird.  EDIT: although, it just occurred to me that the 5.0 motor's water pump spins the opposite way :mad:.
Or would something like this work...
http://www.needhp.com/ford23serpentineunderdrivepulleykit.aspx
although I don't need an underdrive, just serpentine pulleys.
Also, it's just the crank, water pump, and alternator. There is no A/C or power steering. I'm not worried about the alternator pulley, I think there are plenty to be found.
Any thoughts or ideas greatly appreciated
-James
