Pangra wanted
Date: 02/05/2017 01:58 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 08/17/2022 06:27 pm
Date: 09/17/2024 12:35 pm
Date: 09/22/2020 11:33 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
  • Online today: 403
  • Guests: 281
  • Total: 281
6.75" Rear End - Pinion Collapsible Spacer
Started by dave1987, April 07, 2010, 02:57:10 PM
pintokite
yes and wall thickness and i will take them to a friend that has his own machine shop and see what he can do, and price it out.
Phil: I don't think I have seen dotts motor company post here yet, I will do a search and see, email them and find out what they have. Actually, if I remember correctly, you picked up the one for me that I have right now from a dealership near you about a year ago. I think it cost you about the same as what I just bought this other one for ($5.72), but you got it for me to be sure it was the same part I was looking for.
That would be awesome pintokite! I will pick up the one I have at my parents in the back of my wagon full of parts and measure one out for you! I don't know how measure the ribbed spot, but I will do what I can.
Are these all the measurements you need?
Inner diameter of both ends
Outer diameter of both ends
Wall thickness
Rib length
Rib inner diameter
Rib outer diameter
Overall length
pintokite
why couldn't a machine shop turn these out if we had the exact measurements to give then? maybe someone on here could mic this part and put it on line here for everyone.  sounds good to me to help us all out. a friend of mine who has a michine shop an would be happy to do this . problem solved?
check with dotts as they have listed on here a few times.
These are one time use parts, meaning once they are crushed to a specific torque (140 ft/lbs) they cannot be reused. In special circumstances they can be reused, but extreme care must be used not to collapse the spacer any more than it already has been to ensure proper gear offset!
The most common time to replace this spacer is when replacing the pinion flange oil seal. The seal often leaks due to regular wear. This would be the seal located at the front of the differential housing.
The spacer measures about 1 3/8" on the smaller side, and a little over 1 1/2" on the wider side with an overall length of 2 1/8" before crushed. Use this info to verify the part the dealership pulls for you is the correct one!
These parts are not reproduced by anyone and only a handful of Ford Dealerships still have one or two in stock. Here is a list of the dealerships that still have the part available, some even with a discount because they want stuff off their shelves. I keep one around as a spare which I just ordered from Rick Ford Sales in Michigan, which was $5.72 for the part and $5.00 UPS Ground shipping. That's a good example of how cheap you can get it for. Some dealerships may want $35+ for just the part, so call around and see what you can find!
All of these listings are current as of 4/10/2010.
Source - Location - Phone - Quantity
McCrocklin Ford Sales Inc  - Middletown, IN - (765)354-2261 - 1 (currently offering 30% discount)
Nortz & Virkler Inc - Lowville, NY - (315)376-6594 - 2 (currently offering 25% discount, but must mention)
Bob Allen Ford Inc - Overland Park, KS - (913)381-3000 - 1 (possible discount)
Red Taylor Ford Inc - Corning, AR - (870)857-3518 - 1
Sour Lake Ford - Sour Lake, TX  - (800)835-3247 - 1
Kinsel Lincoln Mercury - Beaumont, TX - (800)816-2894 - 1
Dale James Ford Inc - Apple Creek, OH - (330)698-7777 - 2
Dotts Motor Co., Inc - Clearfield, PA - (814)765-9681 - 1
Dickerson Motor Co., Inc. - York SC - (803)684-4225 - 1
