Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 04/08/2018 05:47 pm
Date: 09/17/2024 12:35 pm
Date: 02/28/2018 09:18 am
Date: 08/08/2017 01:44 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 02/18/2017 05:52 pm
  • Online today: 367
  • Guests: 275
  • Total: 275
78 Runabout Questions
Started by RobertConner, January 10, 2005, 06:24:38 AM
CHEAPRACER
QuoteI'm not sure that the stock unit could handle that power.
Anyone know about that?
I blew 2 with a 2.3, n/a, 14:1 comp. 4 speed going about 7,000 rpm in second (I knew 1st would surely blow it). Both times were from wheel hop.
WHEEL HOP = BOOM!!
RobertConner
Rick, I sent you an e-mail. Did you not recieve it?
Hang on, I'll try again. Yes, I am very interested them.
Oh, and Robert will do just fine.  :D
Pinto= Put In Nickel To Operate
HEY, FORD! Bring back the Pinto!
quickrick
robertconner, I guess you are not interested in the headlight surrounds afterall ???
TYDEKE MOTORSPORTS
Tricky Ricky Chop Shop
(740) 701-2908
Chillicothe, Ohio 45601
RobertConner
Quote from: WVBobcat77 on January 12, 2005, 08:17:16 PM
If you have the rearend out of that 66 Mustang your talking about, it'll bolt right in to your pinto.  I'm pretty sure there are 5 lug disc conversions for those if they're not already 5 lug.  Somebody correct me if I'm wrong.
I wish I did have the entire car. No, just the engine, transmission, radiator, and some miscellaneous parts.
But, thanks for the tip, I'll keep it in mind. I may just wind up replacing the entire rear end any, is I do put that engine into it. I'm not sure that the stock unit could handle that power.
WVBobcat77
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
RobertConner
Quote from: Poison Pinto on January 11, 2005, 07:35:07 PM
As for the rear-end conversion, you may be better off going with putting in a whole rear end that includes the 5-lug disc brakes. You'll probably have to go to a coil-spring set up on the rear, since this would be a more modern rear end. If you have welding and fabrication experience (for the mounts on the car's underside), this would be the cheapest and easiest option IMHO.
Hmmm. Well, I don't have any welding experience at all, and to be honest, I want to leave the car as stock as is possible. Changing out the rear-end as you suggest is well beyong both my capabilities, and my budget, at least for the time being. I know that upgrading the front brakes isn't all that difficult, and that there are kits to make the mods I want, but the rear is the problem.
Wouldn't the drum brakes from a Maverick/Comet fit the axle of a Pinto? They are 14-inchers, and I could always have the drums re-drilled with a 5-bolt pattern.
Remember, I am not building a high-performance machine. As it is, my Pinto can, and has, surprise the ricers, in it's stock form. Even with an automatic!
What I am wanting to do is to massage the appearance, and clean up some of the styling problems the Pinto has. IOW, I want it to look as I think Ford should have done it. Once I have the interior redone, and the body mods/paint as I want it, then I'll start playing with the performance aspect.
I have a 1966 271HP 289CID out of a Mustang available to me. (I told my brother not to drive it on an icy road!)
That should make a fairly sweet little rice cooker, don't you think?
Poison Pinto
quickrick
I have a good set that I will sell contact me with offer at
tydeke@adelphia.net
TYDEKE MOTORSPORTS
(740) 701-2908
RobertConner
I have a 78 pinto runabout with the all glass hatch. I really do hate this thing. What I am wondering is, can I use the framed window hatch from another model year on it? I know that I will have to remove the corner pieces in order to allow it to close.
Next, I want to convert the rear drum brakes to discs, and go to a 5-lug rotor.  I want to put some American Racing Torque Thrust-D 14" wheels on it. Are there any kits to perform this upgrade?
Last thing, (for the moment :) ), the "rubber" headlight doors, are crappy and have holes in them. I have looked high and low, and have been unable to find any in better condition than what I already have. So, since the fenders appear to be of the same profile, I was thinking about putting the headlight doors, grille, and hood from a 76 on in place of the 78 pieces. Would this work, or would I need an entire front clip?
Of course, if anyone has a pair of the rubber ones that they would be willing to part with, I could save myself a lot of trouble money, and time. :D
Now, I shall wait with bated breath for someone to offer their wisdom to a new guy.
Thanks in advance.
