1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 01/28/2021 03:49 pm
Date: 02/14/2019 06:27 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 04/20/2017 08:56 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Pinto for sale
Date: 04/19/2017 10:15 am
  • Online today: 529
  • Users: 1
  • Guests: 290
  • Total: 291
  • TommyT
rack & pinion question
Started by dholvrsn, March 26, 2010, 06:15:20 PM
Q.M.C.78
I am doing the same thing on my 1978 cursing wagon with the same xr4ti motor I would replace the hole thing
QMC MOTORSPORTS (78)
1972 351W pinto runabout
1973 2300 turbo pinto runabout
From everything Ive read the MII rack is stronger & bolts right in. Just watch the bolt hole spacing since a lot of rebuilts are newer models & will require the offset bushings to bolt up.
OhSix9
rebuilt racks are cheap.   i think mine ran under 2 bills and comes with new inner tie rods, rubber boots and all the seals.   plus its a quick r and r.   measure your old arm lengths before you pull the tie rods and you should be able to reassemble with a pretty close alignment.     it only affects toe so as long as its the same on both sides and reasonably close you will still go straight down the road
OhSix'
Virgil to Sid
Omaha has thawed out and Wee Beastie and I are coming out of hibernation.
Anyway, the rack & pinion is leaking. Should I replace the seals or the whole thing? It's a '79 wagon with 2.3 (from a XR4Ti) and power-steering.
