Date: 04/15/2017 05:14 pm
Date: 10/10/2019 09:42 pm
Date: 07/01/2019 12:23 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 12/13/2016 10:25 am
Automatic Wagon
Date: 06/14/2019 11:22 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
  • Online today: 2,670
  • Guests: 570
  • Total: 570
Car only runs when cranking ignition
Started by geoff104, March 26, 2010, 09:43:15 AM
geoff104
I might as well just replace it for only  $15.  But I will also check the placement of the actuator rod. Thanks everyone for the great advice!
if you are using the pinto column its more than likely the actuator rod on the column... its out of adjustment..... loosen the screws on the ijnition switch and slide it either up or down the column until you can start it normally.... that fix is a free one.....
Replacing my starter solenoid in my Wagon corrected that same problem!
geoff104
 Thanks a lot guys! I will replace it when I get home today and give it a try!
78txpony
X2 on ignition switch.
If this has the 1978 Duraspark II ignition system, then the module gets two separate power signals - one during cranking and another from RUN.
If you have an ammeter, you should see about 3A of current start to flow when you turn the key to RUN.  This would be the coil and module drawing power.
With engine off, key in RUN, measure for 12V at the Duraspark box (white with blue stripe) and 6-12V at the coil + terminal.
(This assumes the DS2 box)...
-Rob Young
1997 H-D Sportster
Lost Coz
Check the ignition switch. The system is sending 12 volts thru the solenoid to the starter and the coil on start up but when you let switch go to the run position, the 12 stops going to the coil. I had this same problem with the 73 and it turned out to be the ignition switch.
"Pinto's are Cool!"
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
geoff104
Hi,
I have a replica of a 1953 MG TD. It is built on a 1978 ford pinto chassis and 2.3 lima engine. I have a problem which I believe is electrical. While cranking the ignition the car will fire up. If I keep cranking, It will continue to run. The second I stop cranking the car shuts off immediately.
I cannot figure out the issue. I have replaced the ballast resistor, ignition module, starter coil, and the starter for good measure. I tried to start it again and same thing. Any help would be very much appreciated.
Regards,
Geoff
