Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 08/17/2022 06:27 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 02/25/2017 08:45 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 02/18/2017 05:55 pm
Date: 05/22/2018 01:54 pm
Date: 01/24/2021 07:54 pm
  • Online today: 2,457
  • Guests: 556
  • Total: 556
To all those with a t5 and an 8.8 rear end
Started by OhSix9, March 24, 2010, 05:09:27 PM
I used the original and had it shortened and balanced, David says I'm going to twist it like a pretzel when I bolt on the slicks... :P
yeah, i used the mustang 5sp shaft and shortened it 1"... i run the 8.8 and t5 in mine.
well have your tried the stock shaft out of a fox body mustang. Mine may be different since i have a V8 with home made motor mounts. I have a T5 and a 8inch rear and the fox body shaft fit perfect u joints and all. Would be worth a try anyway, i am leaning toward, it fits.  :D
OhSix9
can someone slide under and measure the driveshaft center to center on the u joints.  i need a length measurement, shortening the original shaft 1 inch as suggested is not feasible since the original has long sine been file 13'd
thanks
OhSix'
Virgil to Sid
