Date: 07/04/2022 07:55 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 11/08/2020 02:10 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 04/20/2017 08:56 pm
Racing seats
Date: 10/24/2019 09:41 pm
  • Online today: 367
  • Guests: 285
  • Total: 285
driveshaft
Started by PintoMan1, March 24, 2010, 11:15:50 AM
PintoMan1
hi have the 2000 with the standard 4spd trans. with the standard driveshaft. the rear is from a '77 wagon that had a v-6 in it. i put the rear in my '73 runabout. i changed the axles out for 5-lug and the rotors for 5-lug.
1973 pinto runabout
Hi Pintoman1,
The two piece shaft was there to cut the shock to the driveline with gear changes. It breaksdown with time/use like any old rubber. A company near me (Driveline Service, Ca.) takes them and burns out the rubber, pulls them apart, then re-welds them shorter to one piece. Big ha$$le. The two piece type is VERY heavy. I decided to go with a shortened ALUMINUM drive shaft out of a ford Aerostar minivan. Saves LBS and puts more power to the ground PLUS it's one piece to start. You can also look for a Pinto with an 8 inch rear from the factory as a possible replacement. Like the previous post, not sure of your current combo to be of more help...
Glen,
  Not sure of your whole setup but....
I converted my '73:
2.0, C-4 Auto, 6-3/4"
To:
2.3, T-5,  8"
The good news is that the original driveshaft fit perfectly.
As I said, I'm not sure of your configuration/ parts availability, but if you have a similar arrangement the cost of the driveshaft modification might be near that of the T-5.  I know the local Pick A Part runs a 50% off sale about ever 4-6 weeks.  A T-5 (even without providing a core) is about $100 out the door!
Anyway, just an idea. Sometimes the right mix/match gets more bang for the buck.
Otherwise I'm sorry to say I can't answer your question.
Tom
PintoMan1
hello everyone! i read on here a thread awhile back that changing a 6 3/4" rear out for the 8" rear that the driveshaft would have to be shortend by 1". is this so and has any one had problems with vibration issues? the reason i ask is because i took mine to be cut and rebalanced. and he told me that i may have some issues with vibration and not being able to guarantee the balance bcause of the shaft being two peice and having the rubber in there. is this right and is there anything i can do to keep this form happening?
thanks glen
1973 pinto runabout
