2 liter blocks and heads
Date: 03/28/2018 09:58 am
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 07/08/2017 08:53 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 08/02/2019 04:18 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 04/12/2017 06:57 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
  • Online today: 403
  • Guests: 253
  • Total: 253
That Darn Brake Warning Light!
Started by blupinto, March 20, 2010, 11:03:36 PM
Yeah... only I would have problems like these. Like I said, the brake warning light is faintly illuminated... not fully illuminated like when I start the car. Hey Jim! Come out here and work on her for me!  :lol: lol.
lolololololol holy crap   Tire goes flat when i turn signals on
Becky, how in the world do you dream up these kind of problems??!!  ??? :amazed: Sounds like some of the cars I get assigned to work on: " When I turn on the right signal the left tire goes flat."  :lol:
The shifter has nothing to do with the brake light!!
Lets see, the wiring for the brake light runs along the trans tunnel, but the shift linkage is all internal.
So you're saying that with the clutch pushed down and the shifter in neutral, the light is out. Then when you push the shifter up into first the light comes on. Or is it when you let the clutch out? If that's the case I suspect the wire for the e-brake is rubbing on the clutch cable or the fork, causing it to ground.
Arrrggg!!! And people wonder why I have no hair!!!  :afro: :embarassed: :lol: :lol:
Issues, issues, issues...
      Today, while driving my '73 wagon locally I was unable to put her shifter into second gear (like there's  a barrier or something). I pulled over, put her in first, then second again and this time the shifter went in. However, now the brake warning light has faint illumination... but only when the transmission's engaged. When it's in neutral, there is no illumination.  I realize I have a couple issues here. Could someone please shed some light on them? BTW, (hopefully) before the Knott's trip the clutch will be replaced, as well as some other incidentals.  Thank you to whoever can help me here. :D
